I downloaded i386 from the orginal XP pro disk, now how i install it.
  • 2,878 Answers
You don't. It requires the rest of the setup files to install XP. i386 folders are placed locally for probable use, like when making changes to Add / Remove Windows programs.
Posted on Nov 07, 2012
3 Suggested Answers
furion187
  • 54 Answers
SOURCE: win xp pro setup
if you have the original xp disk with a cd key , then its perfectly legal for you to download a iso copy of xp , and install it, if not try and make a copy of the disk , and use that , or someone u know may have a friend with a xp disk , thats fine also aslong s you use the key that comes with your disk
Posted on Nov 26, 2007
  • 61 Answers
SOURCE: konica minolta 2540 asks for a:\i386 file
WHEN YOU INSERT THE WINDOW CD THAT TIME YOU HAVE TO GIVE THE LOCATION FILE OR IF YOU DO WANT TO DO THIS SO INSTALL NEW WINDOW XP
Posted on Oct 21, 2009
While installing xp sp3. Error message: file missing check i333
Are you sure i333 is not actually i386? The i386 folder contains all the files Windows uses to install XP. If you have XP installed already and it is asking for the i386 folder, it wants you to put the original Windows XP folder into your CD drive. If you are attempting to install Windows XP with SP3, there is something wrong with your CD. To avoid this problem in the past you can do this:
Copy Windows XP Installation Files to Local Hard Disk SourcePath Raymond CC
Feb 07, 2017 | Computers & Internet
Xp Installation Problem on installing xp home system loads files than reboots into 39 minute prompt, but does change from 39 minutes. The Staus lights continue to move but the system doesn't seem to...
Try cleaning the CD with dish soap and water, u may have a dirty disk, be careful (don't scratch it). Try using a different XP install disk from someone you know, just use your product key instead of theirs when it asks for it. Your install disk is failing.
Feb 14, 2011 | Mercury PVCLE266 Motherboard
Can i386 unidrv.hlp for xp pro sp 3 be downloaded from Microsoft?
  1. Insert the Windows XP startup disk in the floppy disk drive, or insert the Windows XP CD in the CD drive, and then restart the computer.
  2. Click to select any options that are required to start the computer from the CD drive if you are prompted to do this.
  3. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  4. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  5. When you are prompted, type the Administrator password. If the Administrator password is blank, press ENTER.
  6. At the Recovery Console command prompt, type the following lines. Press ENTER after each line. cd system32
    ren ntkrnlpa.exe ntkrnlpa.old
    ren ntoskrnl.exe ntoskrnl.old
    cd "c:\windows\driver cache\i386"
    expand sp2.cab -F:ntkrpamp.exe c:\windows\system32
    expand sp2.cab -F:ntkrnlmp.exe c:\windows\system32
    cd c:\windows\system32
    ren ntkrpamp.exe ntkrnlpa.exe
    ren ntkrnlmp.exe ntoskrnl.exe
  7. Type exit to quit Recovery Console. Your computer will restart.
Or go to http://www.ventrilo.com/dlprod.php?id=1 and click on agree.
Nov 03, 2010 | Epson Stylus Photo EX InkJet Printer
Trying to install HP c4280 printer to Dell OPTIPLEX GX620 computer w/ XP PRO. Asking for sRCB.ICM from XP CD ROM Can not locate the sRGB file. Suggestions???
The file might be located on the Dell system disk.
You can also look in c:\windows\system, c:\windows\inf, c:\windows\system32, or in the I386 directory which may be directly under c:\windows
I checked some sources and saw this problem listed only twice--once for Win98.
The name of the file you are looking for is probably SRGB..ICM. I found it on my Win XP system here: C:\windows\Driver Cache\I386\driver.cab
Oct 17, 2010 | Computers & Internet
Konica minolta 2540 asks for a:\i386 file
Oct 21, 2009 | Microsoft Windows XP Professional
Ntldr error on ibm intellistation z pro w/ xp pro
During the XP install, you will be given the chance to set up partitions on the drive. Blow them all out. Completely. Then recreate the partition and let XP install. I expect this will solve the nt loader issue. If, however, it does not, then use the recovery approach below to get the required loader files onto your boot partition.
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "d." This letter may be different on your computer.
    copy d:\i386\ntldr c:\
    copy d:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mar 04, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
HOW TO ACTIVATE XP PRO USING A COPY OF XP PRO?
If it is a copy, and not genuine, it won't work. It is impossible to make an exact copy of Microsoft product CDs. They detect it. Also, if you do install it, you cannot use it without any limitations.
So be legal and search for an old XP CD. It is out of sale now, until stocks last, but it went out 6 months ago.
You can buy and install the superb new Vista or even buy and download it safely from the Microsoft website.
Jan 13, 2009 | Gateway SOLO 200ARC (7004615) Keyboard
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
Jun 01, 2008 | HP Compaq Presario SR1420nx...
Win xp pro setup
Nov 26, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
