Question about Dell Computers & Internet
Fix the color on my computer
The color is blurrie how do I fix it
  • Dell Master
  • 7,627 Answers
A bit vague. Could be the resolution, display, Graphic Card, what do you have as your desktop, is it default, a picture, etc? If you change your desktop does the problem stay the same? Set to default setting in display does it clear? Has the display been changed resently?
Posted on Nov 07, 2012
Color problem
LCD Screen problem if your LCD in under warrnaty so in that case LG provide Free services and they change your LCD Screen please contect LG Services station.
May 11, 2010 | LG 22" FLATRON LCD Monitor
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Blurry after Installing Colro Wheel?
Hi,since you are getting the new silver air pressure version you will need to put an jumper to the dmd board,why because gold version spins different than sliver and that will produce the tv to have color discoloration or bluryness.Good luck and God bless you!
Oct 06, 2009 | Samsung HLR5064W DLP Projection TV
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blurry Pictures
This camera should still be under warranty, so if it's not focussing correctly then let Sony fix it. Before doing so, check that you haven't accidentally left the camera set to macro (close-up focussing) mode.
Jul 06, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
Hitachi 57F500 blurry picture
its the convergence problem in your tv.the ic needs replacement.to fix the problem.its worth getting it fixed.get it repaired.
the cost will be negligible.
Mar 21, 2009 | Hitachi 57F500 57" Rear Projection...
Please help fix my printer
Is the ink cartridge suitable for your computer
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony TV with blurry picture
blurry picture is mainly due to focusing voltage is not proper. solution 1 check & adjust focus control on flyback. 2 check crt base for loose. 3 wire going to focus control on crt base got disconnected due to foreign materials deposit on it. 4 if tv is old possibility of crt getting weak.
Sep 20, 2007 | Akai CF2791 27" TV
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Computers & Internet Logo
55 people viewed this question
Alun Cox
