Question about General Electric Ge JES1451DN Microwave Oven
It just stopped heating. still lights, turns, digital numbers show but no heat.
    Top Expert:
  • General Elec... Master
  • 14,553 Answers
A diode, the large filter in a can, or even the magnetron itself.
Posted on Nov 07, 2012
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
My still fairly new kenmore 1000 watt microwave appears to be operating fine but doesnt heat. What might be the problem?
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Post a new help request with the answers to these questions as well as the full model number from the tag on or in the unit.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Apr 14, 2013 | Kenmore 62622 Microwave Oven
The microwave just stopped working after heating some food. When left plugged in, the light stays on, the table turns, it sounds like it is running, but does not heat anything. The touch controls do not...
The problem is the magnetron. This is the part of the microwave that heats the food. partselect,com likely has your part with a diagram and great prices.
May 14, 2011 | Microwave Ovens
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Stuck on but no power
it is the problem of the faulty heating element .the heating element needs to be replaced to solve this heating problem.
Dec 29, 2008 | Microwave Ovens
If we close the mircowave door the units start to run by itself. - it will not heat, but the light comes on and the turntable rotates it will not stop until we turn the power off - when power is turned...
i think you have a welded controller, either a digital one or a mechanical one. microwave won't run unless you switch it to run. the door switches are safety switches to turn off the microwave once you open the door. if you have a digital controller, you could have a welded relay, if you have a mechanical timer, it could be a welded contact at the timer. another thing is that it should heat what ever you are heating. if it is not heating, check if it has a fuse and if it is busted. some fuse are installed to protect only the magnetron that is why the light and turn table are still running. if there is no fuse to the magnetron, then check the diode from the capacitor to the ground. it could be open. if not then you can have a bad magnetron. i hope i was able to help.
Jun 24, 2008 | LG Microwave Ovens
Everything works... except the heat!
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Microwave Ovens
General Electric Ge JES1451DN Microwave Oven Logo
Top General Electric Microwave Ovens Experts
William Miller
William Miller
Tom Chichester
Are you a General Electric Microwave Oven Expert? Answer questions, earn points and help others
