Question about Honeywell Comfort Control Tower Fan - White
The bottom piece of my fan has broke off is there any way to fix that?
It's the bottom piece that supports the fan so it can stand.
I have aphillips tv, model number 42pfl7603d/10. The stand which it sits on at base of tv has broke, I'm looking to find where I get a replacement one. My walls will not support brackets for it
The only place I found that has one is in the UK
http://www.ebay.com/itm/TABLETOP-STAND-FOR-PHILIPS-42PFL7603D-37PFL7603D-37PFL5603D-42PFL5603-LCD-TV-/360506039050?pt=UK_Home_Garden_LivingRoom_TV_Furniture&hash=item53efd59b0a
Dec 06, 2012 | Televison & Video
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
My equator clothes processor ez2500 is leaking water from the bottom..where can i get parts to fix it?
Please contact Appliance Desk or Equator to get Tech Support & Parts for your machine. their contact no is 713 464 3422 or 713 464 3858 Ext 186 / 175
Sep 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
Thread jams starting with 1st stitch on Bernina 160
since a needle broke, & a new needle was put in, was the needle inserted correctly, normally flat side to the back of the machine, & pushed all the way into the needle holder
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case.
if none of these suggestions help, then it's possible that when the needle broke it could have caused the machine to jump time & would have to be checked at a sewing machine shop
May 21, 2012 | Bernina Virtuosa 160
KitchenAid oven has no heat after self cleaning complete!
You have a bad fan and your probably blew the high-limit in the back of the unit. If this is a built in oven, it's not an extremely simple fix. If it's a stand alone range, you probably broke a heating element during the clean. If its gas, you would have a bad ignitor.
Jan 23, 2012 | KitchenAid Ovens
I broke the table top base for my new Haier HL32XSL LED LCD tv and can not find a part number or place to order a new one.
If it is not practical to glue the base back together with metal-filled epoxy (e. g., J-B Weld), then consider whether you can adapt the hardware to a custom wood base. If you are not comfortable with your woodworking skills, any cabinet shop could probably make a base for you. Be sure to include space for the base weight in the bottom of the wood plate, and specify that it must be capable of supporting the set. (The entire weight of the set including the original stand is 50.7 pounds; subtract the weight of the stand to find the minimum support capacity.) If the vertical arm broke, it may be better to replace it with steel or aluminum channel or tubing.
If the original stand mount scheme is not amenable to a hardwood base, you can build a stand to use the wall mount holes in the back. Be sure to offset the base weight forward enough so the weight of the mounting bracket doesn't tend to tip the set backwards.
May 24, 2011 | Haier HLH326BB 32 in. LCD HDTV
How do I get access to remove & replace the fan in a pmp3000 it looks like the bottom can be removed to gain access. does it also involve removing side panels and handle or can the bottom panel be...
Nope! Leave side panels alone. There are three screws under the front lip (ones that hold the top) and several up the sides of the panel with the faders and the LOWER row of screws on the narrow piece that bends down from the panel with the sliders. Be careful as there are two cables between the top and the lower stuff. One goes to the power supply and the othe goes to a connector under the cover of the power amp module. If you don't have a way to support the top panel while working on the fan you will have to disconnect thosee connectors and they put goo on them which if not careful can break them.
Please be aware that the fan is this is throttled based on temperature sensors on heat sink. Also if the bearings are bad you best replace with exactly the sme model as it has to work with the temp sensors. They have strips that are threaded to act as nuts for the fan mounting. The fan almost doesn't run till you start pushing power... since there are electronics that control the fan, make sure the fan is the cause of inoperation. If the fan is seized up, then replace it.
May 02, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Wiring
12,000-BTU Portable Air Conditioner with Manual ... 3135 30-Inch Oscillating Industrial-Grade Pedestal Fan ~ Lasko ... 42.62 : Soleus Air FCM-30 12-Inch Convertible Stand/Table Fan ...
Aug 25, 2008 | Lasko 1820 Stand (Pedestal) Fan
Honeywell Comfort Control Tower Fan - White Logo
35 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
