My dell laptop needs firewall - Computers & Internet
    Problem Solver:
  • 7 Answers
Use this firewall powerful for laptop and pc windows
http://dl.asdownload.net/1395/Comodo%20Firewall%20v10.0.1.6258%20+%20x64_(asdownload.net).zip
Comodo Firewall v10 0 1 6258 x64
Posted on Jul 15, 2017
  • 826 Answers
Dell now ships all computers ordered through Home and Home Office with software firewalls installed and enabled.
If you have an older Dell PC that did not originally come with a firewall program and you have not already added a separate firewall program to your PC, you will need to purchase a firewall product.
If you are using Windows XP operating system, you can use its built-in firewall called Internet Connection Firewall or Windows Firewall.
If you need any kind of technical assistance to install firewall ,you can contact support cell at http://www.vtechsquad.com/
Posted on Nov 07, 2012
How do i turn off my firewall on my dell xps?
The Windows firewall? Open Control Panel, Windows Firewall, Turn windows firewall on or off. OR Security Center.
Dec 29, 2012 | Dell XPS M1330 Laptop
I cant turn on my firwall
Instructions
Click the "Start" button, open the "Control Panel" and then type "firewall" into the search box in the Control Panel.
Click on the "Windows Firewall" result in the search.
Click on the "Turn Windows Firewall on or off" link.
Click on the "Turn on Windows firewall" options.
Click the "OK" button to turn on the firewal
Jul 17, 2012 | Dell Xps 15 Laptop Computer (Intel CORE I5...
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
My dell inspiron 1720 laptop webcam doesn't work for most programs including msn skype dell webcam manager it said that it can not find my webcam but the webcam only works for yahoo messenger
you can have the webcam workin for only ne application at a point in time also check to see that you have activated the webcam access on the other applications and this time try with the windows firewall and other firewalls deactivated
Jul 25, 2009 | Dell Inspiron 1720 Notebook
ICMP packets not working on Dell Latitude D620
With vista I had the same problem, but when I enabled network fileshareing and set up some network drives it started to answer on ping requests, so it should be one of the networking protocols to enable.
Jan 14, 2009 | Dell Latitude D600 Notebook
Internet page does not fully display
There are two reasons
1) the firewall on Dell preventing it from opening up
2) IE needs to be uninstalled and reinstalled
Try the later
IE closing immediately indicates that one of the files for IE is corrupt or broken or missing. Try and repair the IE file/files that is/are missing/corrupt
Dec 28, 2008 | Linksys WRT160N Wireless Router
Ipac connecting to dell lattitude d620
With pda's the machine is going to recognize and class them connection then device, no way around that. You can get it working in the Dell by adjusting your firewall settings in the security center. There is a section that allows you to add exceptions to the firewall, add the programs for the pda and you're good to go.
Jul 17, 2008 | Dell Latitude D600 Notebook
DELL INSPIRON 1200 NOTEBOOK
Hi
Enabling TCP/IP ports needs to be done from your firewall. Often (these days) two firewalls are in place. One on the internet router/modem and another on your PC. Example McAfee, Norton, ZoneAlarm, etc. Windows XP and Vista also have built-in firewalls (port blockers). If ports are required to be opened, you need to configure it on your internet router/modem and also on your software firewall (as the case might be).
Each internet router/modem and software firewall have specific ways to configure ports so you have to look up the vendors steps or reply with more info and will respond at best effort.
Mike
Mar 15, 2008 | Dell Inspiron 1200 Notebook
Hi
Mike
Mar 14, 2008 | Dell Inspiron 1200 Notebook
Remote firewall??
have you got one live or windows defender?, if so check in the allowed menu to see if your roters ip address is being blocked, also check any other firewall or anti virus programmes.
Mar 09, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
