Question about Oster Kitchen Appliances - Others
What to do if did not pick up all dough - Oster Kitchen Appliances - Others
    Genius:
  • 1,036 Answers
Not much you can do if it's cooked but I always check as it's mixing and sometimes use a spatula to move the flour onto the dough and sometimes it means that the dough is too dry. Try adding a TBS of water on the dry flour at sides.
Posted on Jan 23, 2014
What is spiral hook dough?
A Spiral Hook Dough Hook is one that is used for making bread dough. It mimics the action of stretching and kneading the dough by hand. This develops the gluten content which is the elastic part of the dough that traps the bubbles of carbon dioxide from the yeast.
Oct 14, 2017 | Food Mixers
If program in 6 for dough how long will I have to leave it for and then put in fastbake
typical dough programs run about 1 hour and 20 minutes. This is so the dough can then be baked your outside oven after it has risen. Follow the instructions in your owners manual on how to handle dough after the dough program ends.
Feb 25, 2015 | Russell Hobbs 18036 Breadmaker Fresh Bread...
When I use the dough cycle on my bread maker, the dough doesn't seem to rise enough and is sticky and wet.
Looks like you have the same bread man machine I have. My metod is too unplug the machine for a half hour then put it through a second round of mixing. At the end of secound mixing I place the dough in a bowl greased and large enough for the dough to rise one last time oil top of dough cover with a towel on top of stove turned on set to the desired temperature. Keep dough away from any drafts. Once dough has doubled in size usually about one hour, take dough from bowl and divide it into buns or loafs of bread. Let dough rise again covered. Place in oven bake for about 15 minutes or longer until desired color, bread is done when you tap the top of it and it has a hollow sound, remove from oven let cool in pan for about 5 minutes, then take bread out of pan and place on a rack that allowes air to flow all around it. The reason for the rack is that baked bread that is allowd to cool on a fly surface will cause the bread to sweat on the bottom. Make sure yeast is good not expired or left out in the open
Dec 08, 2014 | Kitchen Appliances - Others
What is a pastry scraper?
This is a metal square with a handle. It is used to change the dough shape or to clean the surface where the dough was. It is used to pick u the dough, turn it over, or separate the dough into pieces.
Jan 14, 2013 | Home
Hi, We have a 3phase Hobart D300 Mixer onboard and the cooks are complaining that there is not enough grunt. I have checked the 3 speeds and they are working finee however when dough is being mixed it...
Hello Veelec,
As the machine is mixing dough it seems that it is getting sluggish. This is caused by the machine being over loaded. Although it is a 30 qt mixer that is for liquid filled capacity. I do not know what kind of dough you are mixing so I will give you a light to medium dough and then the heavy dough capacity. Also on this machine all dough should be mixed in speed 1 or low to keep from damaging the machine.
You will need to know the Absorption Rate (AR) of you dough, to find this you take the weight of the water divide the weight of the water and multiply by 100.
AR = Water Weight / Flour Weight x 100%
The higher the percent the higher the capacity the lower the percent the lower the capacity. Also the temperature of the water will have to be considered as the colder the water the harder the dough it is to mix the dough the batch should be reduced by 15% to 20% for water temperature between 65-75 degrees.
For a Light to Medium dough with a 60% AR the unit capacity is 45 pounds in first speed.
For a Heavy dough at 55% the units capacity is 30 pounds in first speed.
The above capacities are for bread doughs, if you are doing pizza dough, dough nut dough or wheat dough please post back to this thread and I will help you to find the capacities.
I hope that I have helped you with your problem and would like to thank you for using FixYa to find a solution to your problem.
Mar 02, 2011 | Hobart D300 Stand Mixer
Clonking when kneeding dough and not mixing properly
A very clever microwave, making bread!
If and as I suspect you have a bread maker, the beater does clonk a lot as it mimiks the beating motion of making dough and proving. It will pick everything up and stir it in as it rises.
Hope that clarifies for you.
Jan 01, 2011 | Microwave Ovens
When i make bread dough (#8) the dough comes out something between liquid and dough. the dough is extremely sticky. the model is bc-1692. this has happened with the last 4 batches i made yesterday and...
Air temperature in your kitchen, humidity and barometric pressure can effect bread dough. Best thing is to watch it mix and add either water or flour so that the dough forms a nice soft ball and is separated from the side of the pan while mixing.
Hank
Aug 18, 2009 | Kitchen Appliances - Others
I recently acquired a KitchenAid/Hobart Model 4C stand mixer for free. It seems to work okay but I?m in need of a flat beater, dough hook and wire whip as it came with only the juicer attachment. Do you...
A number of attachments were available for the 4C, such as a juicer, a meat grinder, etc., all of which ran off the PTO on the front of the housing.  The only beater, however, was the wire one.  No dough hook was ever made.  I have been told that the motor didn't have the necessary power to run a dough hook.
Jul 25, 2009 | KitchenAid Food Mixers
Gray "gunk" mixed in with dough
I'd contact the manufacturer (Salton, Inc.) customer service site for support, parts or manual. If they don't have them, they should know where to send you.
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "Breadman" (upper-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/bm.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jun 23, 2008 | Breadman TR555LC Bread Maker
Sanyo tv making high pitch noise from loose cable connector
The noise is coming from the fly-back transformer. By moving the cable connector you move the main board. Unplug the TV and remove the back. The transformer has a red wire going to a rubber cup at the top of the picture tube. Looking at the transformer you will see a dough nut shape with a metal piece going through it .. Drive some tooth picks between the dough nut and the metal core. That should reduce or stop the ringing.
Apr 21, 2008 | Sanyo DS31520 31" TV
Kitchen Appliances - Others Logo
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
