Question about Garden
Kawasaki fh500v smokes
Engine has approx. 600 hrs on it. engine smokes( white smoke) when running. has new carb..
ImpalerCo
  • 13 Answers
SOURCE: Constant white smoke while running
White smoke is oil burn off. First off, check the oil level (sounds dumb, I know) and make sure the oil is not overfilled. Overfilling would be the easiest solution. If there is oil burning onto the spark plug but the oil is not overfilled, I would think rings... possibly scarring in the cylinder. Something allowing the oil to seep past the piston into the head. If the cylinder is scarred, there are .020 oversized pistons and rings available for the engines, rebore the cylinder and place those in.
Posted on May 16, 2009
moretons
  • 155 Answers
SOURCE: My cub let out a big ploom of white smoke and shut off.
This is caused by two things low oil level and overheating, The oil also has a cooling agent in it so if it was run low the engine would not get lubrication and overheat possibly causing the conrod to break if you say its only 10 hrs old i would be talking to the dealer you purcased it from or the engine manufacturer. its unusual for an engine with very little hours on it.
Posted on Jul 27, 2009
  • 77 Answers
SOURCE: Brand new weed eater lawn mower blowing white smoke.
Pull air filter see if theres any oil in it,make sure the oil isnt overfilled. Push mowers usually smoke like that if theyre overfilled,or tipped on thier side,if there is oil in filter simply take filter off,drain oil to correct level,and run it till smoke goes away. If none of this is the problem rings are probably shot. Weedeater is a cheap brand and theyre made cheap too,not made to last.
Posted on Aug 12, 2009
  • 68 Answers
SOURCE: Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Posted on Sep 06, 2009
  • 38 Answers
SOURCE: Lawn mower running rough
adjust the carby. also u might want to replace the diaphragm in the carby. might work wonders
Posted on Apr 03, 2010
White smoke coming from my suzuki intruder lc 1500
First check carb gasket. White smoke usually mean cooler leeks (for liquid cooled engines)- suspect head gasket. But this is just if smoke coming from exhaust not engine.
Aug 20, 2012 | 2000 Suzuki VL 1500 Intruder LC
1997 Kawasaki VN 750 Vulcan has white smoke and running rough.
Hi, Walshy9587 your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a nice day.
Sputtering White smoke Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
White smoke coming from engine Kawasaki Vulcan Forum Vulcan Forums
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
1997 Kawasaki Vulcan 750 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 14, 2012 | 1997 kawasaki VN 750 Vulcan
1995 Kawasaki ZZR 600 fuel overflow
Hi, Anonymous and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
9. Contaminated fuel tank.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Fuel Tank Leaking internally into overflow vent pipe
Carbs leaking Here is how to fix it
Kawasaki ZX6 ZZR600 90 97 pdf
Kawasaki Ninja Owners Manuals
Mar 21, 2012 | 1995 kawasaki ZZR 600
2005 Kawasaki KX 125 exhaust black smoke
Hi, Wieczorekjoe your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
KX250F Smoking out of exhaust What needs replacement
Carburator Theory and Tuning
https://www.howtomotorcyclerepair.com/images/Kawasaki-KX-125-KX250-Service-Manual-2003-2004-2005-2006-2007-2008.pdf
OEM Parts for Kawasaki 2005 Kawasaki KX125 Owner Manual
Apr 03, 2011 | 2005 kawasaki KX 125
Have a toroZ5035 mower 90 turn) with kawasaki engine. **** smoke appears on start up, but goes away when warmed up. choke must be kept on at least halfway or motor dies. changed plugs and cleaned air...
**** smoke sounds bad, If what you meant was white smoke then I know what is going on with the mower. The white smoke is from the extra oil in the cylinder head. There are tow causes for this. #1 the engine rings are worn and will not prevent the oil from running into the combustion chamber as the engine sits. #2 the carburetor is leaking fuel into the oil and thinning it out. This thin oil bypasses the rings easier and drives the oil level up too. I would recommend a carburetor rebuild. You can get parts from a local dealer like www.arcolawn,com Good luck barterjoe_64.png
Mar 23, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
I have got a Hyundai Accent 2000 model , i have replaced the engine with a new sleeve , Pistons, Bearings and rings .I have already run 600 Kms .There is no engine misfire or trouble in running. But i...
Well, you have to be quite specific with the color of your smoke. White smoke indicates water vapor and Blue smoke indicates oil. If the mnornings are chilly, you can almost always expect to see water vapor smoke. Another thing is how much smoke is it? You can try an engine oil additive such as Restore or change the type of oil you use in your engine. It's hard to say without a lil more detail, but if you replaced all that and it runs smooth and quiet, then I wouldn't worry a whole lot about it. Without being remanufactured, a 2000 engine aint gonna run like new in 2011 no matter what you do to it. Hope this helps.
Mar 19, 2011 | 2000 Hyundai Accent
My exhaust is shootingout a smelly white smoke
The smoke is engine coolant, u have a leaking engine head gasket.
Oct 11, 2010 | Hyundai Motor 2002 Sonata
New exhuast plugs wires jetted carb stilll getting smoke from one pipe ,from front jug ,but bike runs excellent. any ideas
What color is the smoke? If the smoke is white, it's oil smoke. If it's fuel, it'll be black smoke.
Generally, black smoke from the exhast indicates a too rich mixture for one reason or the other. You said you rejetted the carb. This could be part of the problem. You also said that it's only out of the front pipe. If you rejet the carb, it effects both cylinders. If you have a vacuum leak on the rear cylinder, this could cause the front cylinder to run rich.
If the smoke coming from the front cylinder is white smoke, you may have a oil problem. It could be rings, a valve stem seal, or a head gasket leak. But, unless the smoke is heavy and the bike runs good, I wouldn't worry about it. If it bothers you, have a leakdown test run on the engine. That should tell you where the problem is. Or, just do a top end overhaul on the engine and be done with it. Have a new set of rings installed or have it bored and new pistons if needed. Also have a valve job done on the heads. This should solve the problem as you'll have to replace the intake gaskets when you take the intake and heads off.
Don't just keep throwing money at the problem. That gets expensive and is only successful part of the time. Anytime you have a problem with one cylinder only, whatever is wrong is confined to that cylinder. Anything that you do that effects both cylinders is usually useless. I would suspect a valve stem seal on your bike. You didn't say how many miles you have on the engine nor what type of carb you're running.
Good Luck
Steve
Jun 20, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
MY Kawasaki FH500V commercial lawn mower engine won't start.
Try cleaning the throttle body. If it runs on carb-cleaner being sprayed into the intake then you have a fuel delivery problem, if not you'd be more inclined to more serious mechanical failure. I assume if you use it every day you do the regular oil changes, air filter cleaning, and air-cooling system cleaning, correct? Please indicate if you had a white smoke, blue smoke, or black smoke from the mower too. The motor spins freely when attempting to start, and just doesn't fire, correct?
-JMFT
Oct 01, 2009 | Toro Lawn Mower With Toro Power Tools
My bmw x5 3d relising so much smoke from exust
Just had my car in the garage with horrendous white smoke coming from the exhaust. The problem with mine was a blocked crankcase breather. When blocked oil is passed into the exhaust system apparently.
Problem solved by the mechanic and half a day in the garage with the engine running to burn off the excess oil in the exhaust and the problem was solved. Had gentle ride out to the coast yesterday approx 1.5 hrs each way and the smoke has gone.
Good result for £160.00. I dread to think what the dealer would have charged.
Sep 19, 2009 | 2003 BMW 5 Series
Garden Logo
228 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
