Question about Weller 8200 Soldering Gun
How to install a 8100 weller soldering gun tip
SOURCE: Replacing tip
i have an old 8200 and i just bend the ends of the replacement tip, then i just tighten the bolts. that is how the tip was on the when i bought the 8200. cheers
Posted on Dec 29, 2008
jcox983
SOURCE: Weller model 550PK heavy-duty soldering gun is slow to heat up
It depends on what you say is slow, I have used weller soldering guns and desoldering guns for about 30 years. They come up to top heat in about 3min. If it is taking longer than that then there is a problem with the heating unit. You can call weller tech help number, should be on iron base and they can tell you how to test the heat unit.
Posted on May 06, 2009
bulldogchief
  • 388 Answers
SOURCE: Weller 8200 100/140W replacement light bulb?
The bulb's part number is 7333. You can order a replacement bulb here for about $2.50 :http://www.e-sonic.com/aboutus/cat/S/soldering%206.pdf
Posted on Sep 14, 2009
Testimonial: "Thank you. Bulb voltage is actually whay I was looking for but I did not specifically ask for this.:-) Perhaps a 7333 bulb is a universal #."
  • 1244 Answers
SOURCE: weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
Posted on Jan 22, 2010
  • 518 Answers
SOURCE: Need to download a manual for the Weller universal
just type in weller 8200 sol gun in search and it will go there
Posted on Jul 05, 2010
Testimonial: "After many futile tries on my web browser, your recommended web address contained the answer I was looking for. Thanks alot."
TIPS BURN OUT
It's better to get a soldering station instead.
Apr 26, 2013 | Weller 8200 Soldering Gun
Wont heat enough to solder
Hello, does your solder iron --Weller- humming? Also, is the solder tips the right tips for you Weller woldering gun? Are the tips tightened on the end of the solder gun prongs?
Well, if it is humming there is internal short in the windings inside of the gun. Don't mess with. Recyle it by taking the copper, brass, aluminum, and other metal out. Now, if it is not humming.
Make sure you have right tips, make sure that the tip is tightened in the soldering gun prongs.
The working principal of these soldering guns is that they work on low voltage and very high current. The current is regulated to keep the tip from burning into. Just enough current to heat the tipe to a certain temperature.. It can shock you but there not enough voltage with current but it will hurt. and could burn you. Be careful and lots of luck...GB...stewbison
Aug 04, 2011 | Weller Standard Tip: 7200
Is the weller 8200 comparable to the "Old Weller
Hello, your Weller 8200 soldering gun is rated at 140 or 160/100 watts. While the junior was about 70 watts. Go to this web site for parts: www.e-sonic.com/aboutus/cat/S/soldering%206.pdf GB...stewbison
Apr 23, 2011 | Weller Welding Tools
How do you use an weller wsb25hk change tips?
Hello, just loosen the set screws on the end of the soldering gun barrels. Install new tips and tighten the set screw--sung! If your soldering iron requires that the tips have a 90 degree angle on their ends. You can bend them but be very careful because you can break them end off. The tipes are made of copper with some other alloys and the are kinda brittle. You can do. GB...stewbison
Jan 13, 2011 | Weller Standard Tip: 7200
Need to know where I can get tips for a 8200 gun.
Sears Hardware carries Weller and and has tips for the 8200 Weller Soldering Gun, I just swa them yesterday at Sears Hardware.
May 21, 2010 | Weller 8200 Soldering Gun
Weller soldering gun replacement light bulbs
Jan 22, 2010 | Weller 8200 Soldering Gun
Weller D550 fried brand new tip
are you sure you bought the H.D. tip this is the big gun
Jul 12, 2009 | RTO Weller D550 Soldering Gun
Intermittent heat on Weller D550 although lights stay on. When not working, moving the terminals may get it to start working again. Sometimes, just moving the gun will interrupt the heat. Continuity...
Heat gun tips often get bad electrical connection where the nuts tighten to the tip ends. Remove the tip, clean the ends, re-install the tip, making sure the nuts TIGHTEN onto the tip ends. Your problem is common and always caused by a poor connection at the tip ends/nuts.
Jun 20, 2009 | RTO Weller D550 Soldering Gun
Weller 8200 Soldering Gun Logo
115 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
