Question about Lands Phones
How to open phone line on nec ip2ww-2opbox - Lands Phones
Nec Dterm 80 manual
Several phone vendors post user manuals on-line. Dterm 80 is a phone that works on about 10 NEC phone systems. Find out which system you have; Pro II, Elite, IPK, IPK II, SV8100, 8300, 8500, and so on, then Google your system+user manual+PDF.
Jun 10, 2014 | NEC Lands Phones
My cordless phone in my restaurant is finally had it. NEC wants $300 for a new cordless! If I buy a different cordless made by a different company, will it be compatible with my NEC corded phone?
No, You must use an Nec telephone, thus the price. If you need it on one line only you could connect any cordless phone on the dial tone before the NEC system. This will ring and also you can call out but you will not be able to transfer from or to it and you cannot use any NEC system features.
NEC $279.45 from me gregdownes@verizon.net
Jan 11, 2011 | NEC DSX Systems NEC-780020 DTR-1-1 BLACK...
Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Mar 12, 2009 | NEC Electra Elite 32D-1 Corded Phone
Pick up line ringing Dterm 80
Line ringing preference on our NEC phone
Do not get outside line, just press:
#7579 to turn on, #7576 to turn of
Then press SPKR to exit
Feb 21, 2009 | Toshiba DKT-2010 Corded Phone
No dial tone on a nec dtu
The NEC phone is probably a business multi-line digital phone, requiring a phone 'back-end' system. Will not work on an analog 'home' phone line.
Feb 16, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Nec dterm phones
You can use it with just about an VoIP system that you may currently be running. Some features will probably not be able to use but yes it needs to have a PBX/ Server.
Dec 01, 2008 | NEC Dterm DTP 16D-1 Corded Phone
RE: NEC DTP-2DT 2 Line Digital Phone HandSet
i believe the nec dtp-2dt maybe a phone system phone for offices. you didn't mention if it's for home or office use.a phone system phone will not work in a regular phone jack. it needs to go thru a phone system. also if you buy any 2 line phones, you need 2 lines for both lines to work. you can also have a 2 line phone with only 1 line and order a 2nd line if needed
hope this helps
wg
Jan 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Electra professional nec
I am making the assumption that only line 1 has caller-ID. Both of my suggestions require services on the phone lines themselves, and not thru the phone system.
  1. Line 1 needs features on the line to allow three-way calling. Then you would hit the Recall key after answering to send a Flash to the Central Office to dial the 2nd number. This takes the transfer away from the phone system and puts it on the CO. This requires more time and effort on the staff answering phones, and if a calls comes in while this is in progress, it's going to roll over to another number in the hunt sequence anyway.
  2. Get Caller-ID on all lines.
Jan 11, 2008 | NEC Electra Professional ETW-16DC-2
Lands Phones Logo
194 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
