Question about GE XL1800 1100 Watts Microwave Oven
I have a ge xl 1800 and the vent stays on when the door is closed. plus the inside light is blown. what's going on please. thank you.
  • roneasy2001 Jan 06, 2009
    yeah i fixed it. now let me tell you how idid it , first give me your credit card number or i accept cash for $1.00 i will tell you howwwwwwww.. ha ha ha ha ha.
  • nermal64 Jan 07, 2009
    I have the same problem with the vent running while door is closed, but my light works. Bought new, but with no manual (floor display?) Tried, but can't download manual from web site.
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
You can download GE owner's manuals and installation instructions free here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
GE XL 1400 Spacemaker Microwave
Clean all the visibility of the microvave which causes the light switch logged. pls consult the user manual in cleaning the oven.
may help, melnavz
Apr 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker profile xl 1800 moving vent will not close
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl1800 vent fan
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
No turntable, no heat. Light, vent fan and keypad all work...
That would be a problem with your primary interlock switch or its mount.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The interlocks are highlighted in the diagram below.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 28, 2008 | GE XL1800 1100 Watts Microwave Oven
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 MW recirc motor open and closes flap on its own every 10 secs.
Sounds like the control board has gone bad and will need to be replaced.
Oct 13, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL 1800 - Noise while heating
Maybe you and the person from the post below could get together and help each other? http://www.fixya.com/ThreadView.aspx?prdid=489218&thid=130453
Mar 25, 2007 | GE JVM1660 Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
62 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
