Question about Cell Phones
How to remove the sci in my calculator - Cell Phones
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cell Phones Master
  • 102,366 Answers
Press the SET UP button. Press 1 to select "FSE". Select something other than "SCI". Bear in mind that no matter what you select, the display will indicate the current mode by lighting up the appropriate indicator.
Posted on Nov 06, 2012
Security proplam
Posted on Oct 19, 2013
How to remove G fix sci
You may want to reset the calculator. Press the key sequence SHIFT 9. Do not be surprised if you see that G has been replaced by D. These two remind you that the angle unit is set to gradian (G), degree (D). There is a third angle unit, the radian (R).
Apr 21, 2013 | Casio FX991ES Scientific Calculator
I want to remove rad and sci symbol from casio fx-901 calculator display
For removing SCI symbol press following keys Shift-->Mode-->8-->1.
You can't remove RAD symbol, you can only replace it by DEG or GRA.
Aug 22, 2011 | Casio FX-115ES Scientific Calculator
How can i get fix off my calulator
To get out of the fixed decimal mode, press the MODE key until you see the screen giving you the three options "Fix", "Sci", and "Norm". Select Norm 1 or Norm 2. If you select a Sci mode, you'll get "SCI" on the screen in place of the "FIX".
Jun 23, 2011 | Casio FX-300MS Calculator
Can i convert a decimal calculated into scientific notation, cause sometimes important numbers are missed, because they are cut off, and not converted into sci. notation automatically
This has nothing to do with the SCI display mode. Your calculator can only display a certain number of digits. The screen is limited. The maximum number of decimals you can display is 9.
By going into SETUP 1:FSE you can choose the display type FIX, SCI, ENG, NORM1, NORM2, then set the number of decimal digits.
Be it as it may, if a number is too large or too small it will be displayed in SCIentific format.
Note: Not all digits are important, only the first ones are. That is why in science one introduces the notion of significant digits. It depends on the precision of all the numbers involved in the calculation. NO RESULT can be more precise than the least precise number involved in its calculation.
Mar 02, 2011 | Sharp ELW535 Calculator
I just wanted to know if there is an engineering key or function like sci on the fx115 es casio calculator
SHIFT MODE 7 for SCI and SHIFT MODE 8 for ENG. Each of them needs to be followed by a digit.
Mar 02, 2010 | Casio FX-115ES Scientific Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
How to switch off the REG and Sci function
press MODE then select CALC then COMP to remove REG.
press MODE again select DISP then NORM1 to remove SCI.
May 20, 2009 | Casio FX-115W Plus Calculator
Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Jan 09, 2009 | Texas Instruments TI-30XA Calculator
Turn off sci
To turn off SCI, press the MODE button, then press 9. MODE 9 is the function for NORM, which means normal use. DEG is always on, but if you want to clear SCI or FIX, MODE 9 will clear these.
Nov 19, 2008 | Casio FX-250HC Calculator
Cell Phones Logo
77 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
