Question about Garden
Need craftsman 32cc blower fuel line diagram (358.797251)
  • 257 Answers
SOURCE: cant get my 25cc craftsman blower to start...
try checking to see if spark plug firing ,, if it is not firing the magneto is bad,, just follow the plug wire and you find it,, here is a way to check the fire,, take spark plug out take a pair of rubber or plastic coated pliers and hold to some metal while someone pull it if you dont see spark then this is your problem,, hope this help you
Posted on Sep 02, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Posted on Oct 13, 2012
trippssmengi
  • 76 Answers
SOURCE: McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
Posted on Jan 06, 2009
  • 398 Answers
SOURCE: Lenght and position for Ryobi RY08548 Blower fuel line in gastank
take off the fuel filter and see if that works . if it runs then it needs a new fuel filter. keep me posted
Posted on Apr 14, 2009
SOURCE: craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Posted on Jun 12, 2009
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Hi jfkunz
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
Fuel line diagram for craftsman 32cc weedwacker weed eater
digrama for weed wacker 32cc modelo 368791156
Aug 23, 2012 | Garden
Repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc blower stalls
Jun 10, 2009 | Craftsman 4 Cycle Blower/Vac
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Apr 04, 2009 | Garden
Garden Logo
572 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
