I have an OPH 614 - 80 which we used on the 29 min wash. It went faulty and so we used the 44 min wash. Now it has a mind of its own it sometimes boils our clothes or just keeps washing. We had an engineer out to it not long after we got it. He removed the control nob and sprayed something in and turned the nob back and forth quickly which seemed to solve the problem. He said they were known for this and he would probably be back to do this again and it could be a problem with the programer. So when we then had this problem again I did what he did. This has worked for a while but this dose not solve it any suggestions.
    Top Expert:
  • Washing Mach... Master
  • 41,817 Answers
Failing timer
Posted on Apr 11, 2017
Fix it Matt
  • 14 Answers
SOURCE: Bosch maxx 2860 won't do a quick wash anymore
The timer sticks at one place.
Quite a common problem. The least common is the actual failure of the timer itself. It is much more commonly caused by the failure of the heater, water valve, pump, a broken wire or even a blockage in the pressure system or waste system.
Posted on May 03, 2009
SOURCE: oil leak in washing machine
Sounds like the transmission is leaking. These transmission don't need to be full of oil to function. But, if it's leaking a lot, like tablespoons, it should be checked. It's not the end of the line. Just may need a service call if it's a plentiful leak.
Posted on May 05, 2009
SOURCE: My Hoover Optima OPH 714 D washing machine won't start
Hi, the lights are coming on, but the door lights keep flashing and then nothing happens
Posted on May 09, 2010
FitzOriginal
  • 842 Answers
SOURCE: hoover washing machine Mod OPH 714D Error E16 in
After far more research than I usually have to do, It seems that E16 means "O/C Heater"
Which means that the heating element is open curcuit. Which menas......
Either the heater element has a wire off at the back, or more likely the heater element is burned out.
They are easy to replace. Pull the machine out and remove the rear inspection plate at the bottom of the body (I think this machine has one!, sorry if it doesn't).
At the bottom of the drum, you will see a atainless steel cover, about 4 inches limg and a third of an inch wide, with rounded ends. There will be 2 spade connectors with wires in them (1 either end of the plate) and a 10mm nut in the centre. The nut tightens up a squeeze plate inside that crushes up a rubber seal to hold it in place. Undo the nut fully (you may have to push the little stud bolt that is now exposed in a little to free it off) The element should now withdraw if you grab hold of the spade connectors and tug a little to break the seal before you withdraw it.
Replacement should be the reverse of removal.
Google "Hoover washing machine heating element" to find yourself one on line, or ho to your local Hoover parts stockist
Posted on Jun 30, 2011
Testimonial: "thanks for your help great, having more problems now so it has to go!"
SOURCE: Tricity Bendix BIW 105W Washing Machine
on a bendix 105w if you set spin programme(15) the pump comes on for 10 seconds then nothing, the belt is ok. on other programmes it washes and rinses as normal, just wont spin. help!!!
Posted on Aug 22, 2011
I am trying to re-install my pixma 600R but each time i get to 44% 13 min it stops. I have disconnected firewalls and follwed suggestion in manual. Can you please help. Many thanks. kev
Hey,
You may have a faulty install media, I will get you a download to the setup program in one minute and you can try installing with it.
Sep 11, 2008 | Office Equipment & Supplies
I need the torque setting for refitting a cylinder head on a mk2 golf 8v gti
1990 VW Golf 1.8L 8 or 16 valves.
step # 1 29 ft/lbs
step # 2 44 ft/lbs
step # 3 turn bolts 180deg. further in one continuous movement, two separate 90deg. turns may be used.
Dec 26, 2009 | 1990 Volkswagen Golf
Specification for Sprokets
I asked mechanic to short gear bike and I went for a 16 teeth front sproket. It gave crazy acceleration but it stole 15kms/h from the top speed. I never ride on top speed in any way, it is 270-285 kms per hour and here, we do not have any good road for this sort of speeds. I went for 16 front 44 rear sprockets combination and I like it. It is good for a fast street racings as well as for a long distance trips.
17 - 44 is standard gearing.
http://www.bitzforbikes.co.uk/Rear_Sprocket._%28high_carbon_steel_to_OEM_standard%29-ref-2515-405-224-23.html
http://www.bitzforbikes.co.uk/Front_Sprocket._%28high_carbon_steel_to_OEM_standard%29-ref-2490-405-224-23.html
Nov 21, 2009 | 1999 kawasaki ZZR 1100
My gsa-t20n will burn regular disks but will not burn DL disks all of a sudden...it burns most of the way then Nero says it cannot finalize disk. 22:48:29] NeroVision [22:48:29] NeroVision 10:36:44 PM ...
Hello there jpd0490.
Here's your geek-steer ...
There are principally two chief causes for this type (calibration) of burn failure:
  1. Inadequate quality media (disks). Verbatim is always a solid choice. However, more important than the brand-name disks are sold under, is the actual manufacturer. You can determine this with the aid of a little software tool called "DVD Identifier". There is an entire sub-culture devoted to tracking the best media available, right down to the manufacturing lot level.
  2. Drive failing. Since you say that it works consistently otherwise, this option is unlikely.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 10, 2009 | LG GSA-T20N DVD±RW Dual Layer Burner
Eurovoxcodes telewest 5a01
try 00
AA B7 D1 D9 CE 8E 83 AF
OR
01
A1 38 06 29 24 29 8D 2B
Apr 12, 2009 | StarTech.com StarView SV211K 2-port KVM...
Need new codes for eurovoxmax need new codes dublin
codes for eurovox 5a01 6/5/09 aa b7 d1 d9 ce 8e 83 af a1 38 06 29 24 29 8d 2b should work ok bristol area
Jan 02, 2009 | Televison & Video
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
