Nordyne furnace model E2EB-015HB - Heating & Cooling
  • 14 Answers
SOURCE: I NEED THE WIRING DIAGRAM
contact nordyne local dealer and they should be able to get on for you. otherwise go to google and search for factor and e-mail them for 1.
Posted on Jan 10, 2009
  • 659 Answers
SOURCE: Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Posted on Apr 11, 2009
  • 116 Answers
SOURCE: My central heating and air-conditioning unit completely stopped working - the model# is e2eb-015hb
manually bump the contactor whare the main power comes in with a insulated object isf unit starts then check for call from stat on stat wire from common to red 24v ac transformer good or see if indoor fan comes on next check call from stat common to yellow 24 v then look for low psi switch to see if it has it locked out could be low on gas
Posted on May 09, 2009
dj_relly999
  • 4070 Answers
SOURCE: Outside unit will not turn
Hi! You may want to start on having the power supply checked. Good cause why the unit won't power up. Have the compressor checked too just to be sure.
Posted on Sep 15, 2010
  • 8 Answers
SOURCE: my furnace keeps blowing fuses
The first thing i would do is shut off all the power to the unit and disconnect all the wiring from the thermostat. then i would install a jumper wire from R to W on the circuit board and see if the furnace runs good. if it runs good and does not blow a fuse, your problem is in the wiring between the t-stat and the furnace. If this does not help, please indicate if your system is a straight a/c, furnace system. or if it is installed with a heat pump. also does it make any difference what the temperature is outside. for example, does the fuse only blow when the temp drops down into the 30s or does it not make any difference.
Posted on Nov 20, 2010
We have a Nordyne AC/Heater model # E2EB-012HA. My problem with the unit is that the heater will not turn off and the blower motor also won't turn off unless we switch the breaker to off. Also I...
my nordyne e2eb-012ha after running shuts off most of the time we have to reset the element breaker to get it going again. any ideas can"t find directions to how to get behind breakers thanks morris
Nov 28, 2012 | Heating & Cooling
I need a wiring diagram and sequencer part Number for e2eb-015hb nordyne electric furnace
any sequencer will work as long as you have the same number of stages. hope this helps.
Aug 09, 2011 | Heating & Cooling
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
I NEED THE WIRING DIAGRAM FOR A NORDYNE MODEL #E2EB-017HA
Dec 11, 2008 | Intertherm P3RA-048K Air Conditioner
Need help hooking the right colored prong wires onto my sequencer
There should be a wire diagram on the back side of the panel you took off to get to the sequencer
Nov 13, 2008 | Heating & Cooling
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
