Question about HP Photosmart C7180 All-In-One InkJet Printer
Error code oxc18a0206 - HP Photosmart C7180 All-In-One InkJet Printer
    Scholar:
    New Friend:
  • 43 Answers
Try with a different set of ink cartridge if it does not work follow the below steps
1.Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
11. connect the printer directly to the walloutlet
12. Still issue is not resolved then do a reset on the printer : Disconnect the power cord from the back of the product.Wait for 20 seconds, and then press and hold # and 6 on the product Control Panel. Connect the power cord to the back of the product and then release the buttons when the product turns on.The product resets to factory defaults.
13. Issue not resolved then service the product
Posted on Nov 08, 2013
HP Photosmart C5180 printer error message Oxc18a0206
Use your machines own programme to clean the ink heads
Feb 20, 2016 | HP PhotoSmart Office Equipment & Supplies
How do I fix an hp printer with Oxc18A0206 error message
Try this
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
May also be a failed printer or clogged ink from lack of use or bad ink.
Oct 17, 2014 | HP Photosmart D7360 Printer
Oxc18a0206 hp photosmart c7280
Unplug power cord from printer and electrical outlet wait 30 seconds and hold in help and OK buttons while reconnecting power cord. continue holding buttons until screen turns black turn printer on and continue this helped me.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 13, 2013 | HP Photosmart C7280 Printer
What does printer code Oxc18a0206 mean?
its like a HEX code
ask a software debbuger on assembly programming.
Jun 27, 2012 | HP Office Equipment & Supplies
ERROR CODE FOR PHOTOSMART C6180 OXC18A0206
Thank you very much PINEWORK your solution 1. work perfectly and now it working great, really appreciate your effort to save a lot of time and money.Thanks
Mar 28, 2012 | HP Photosmart C6180 All-In-One InkJet...
Error message 0xc18a0206
Hello and Welcome!
The error
Oxc18a0206 is mostly occurred in HP printers
To solve the error code
Oxc18a0206,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
Sir, If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
Dec 14, 2011 | HP Photosmart C7250 All-In-One Thermal...
ERROR: Oxc18a0206
Remove the Cartridges, Clean the Contact Points
Install the Cartridges back. the error should go off.
If the Issue still persist, Disconnect the power Cord from back of printer, Press and hold the OK and CANCEL button and connect the cord back.
Probably.. this could be Hardware Issue if you still get this Error
Jun 24, 2010 | HP Photosmart C5180 All-In-One InkJet...
Error code Oxc18a0206 ink system failure
I had this same exact problem. Try doing:
I had to go through multiple tries of the solution above. I turned it back on, it shut off and I turned it back on again. I tried to print something and sure enough, it did a maintenance cycle and it works again.
This did not work the first time but after 3-4 times of doing both, TA DAH, it went through a lengthy maintenance cycle and then started working. Persistence paid off
Jan 22, 2009 | HP Photosmart 3310 Printer
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
35 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
