Question about Adobe PageMaker V7.0.2 for PC
Adobe acrobat reader is not opening...
Hi all im having problems in opening opening adobe acrobat reader.when i open adobe acrobat reader my system hangs as it starts taking 45 % utilization of CPU. plz suggest how should i get rid of this prob... vikas khirwadkar
  • vikas khirwadkar May 25, 2007
    hi...thanx for ur solution bt my case is a bit different...i work in a comp and administrator says that my profile has been corruted on my partcular pc...but when i log in at anothers pc acrobat reader in my profile works properly...bt it fails to work on my terminal...can u suggest..some solution
  • 3 Answers
Do a repair or reinstall of the Adobe Reader 7.0.9
http://www.adobe.com/products/acrobat/read...llversions.html
Posted on Nov 16, 2007
  • 883 Answers
If you have the original install disk for adobe acrobat reader the uninstall the program then power down then re-install the program
Posted on May 23, 2007
How to Fix Adobe Acrobat Reader
Adobe Acrobat Reader needs to be updated. It sounds like your automatic update is turned off.
Mar 10, 2015 | Adobe Acrobat® 8.0 Standard Full Version...
What Adobe Acrobat Reader for Mac 10.3?
Hi Gary Another of Adobe's wonderful updates! Sing;e click on a pdf file and then do Command-I (get Info). Near the bottom of the info window select 'Open with Preview' then select the open all with preview,That way you should negate Adobe reader.
Jan 14, 2013 | Apple iMac G4 Desktop
How do you open and edit pdf documents on a hp omni 100 pc
You need to download and install adobe reader or PDF installer. In order you to edit, open and modify files in pdf.
Oct 09, 2011 | HP Omni 100 PC
IM having a problem reading pdf files the file downloads but I cant get it to open
make sure the Adobe Acrobat reader is properly installed or not.how ever it is better to update the Adobe Acrobat reader to latest version.Visit www.adobe.com and choose ypur update .Regards..
Jul 13, 2011 | Dell Dimension 1100n (DIM11N) PC Desktop
I cannot open files on my computer that require them to be open by adobe which I have on both my laptops. The files save then you have to open them with a program but it trys to open with word which does...
I assume that you mean Adobe Acrobat reader. First of all make sure that you already have installed this program. Go at start - programs - and browse all programs to locate that Adobe Acrobat Reader existing. A good idea is to open it in order to check that it's fully working. In case of a problem download it from this official link. Since you are sure for the Acrobat Reader's existence, right click at any pdf file (these type of files open with Acrobat Reader) - choose open with - go at the bottom of the new window "choose program" - at the new window select Adobe Acrobat Reader (in case it is not available click on browse and navigate at the C:\Program Files\Adobe\Reader x.x\Reader, select the file AcroRd32, hit open - check the box for "open this kind of files always with the same program" - hit OK and you are ready. From now on every time you will double click at a pdf file the Acrobat Reader will open this file.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 05, 2011 | Adobe Computers & Internet
I keep getting messages ..could not find acrobat External windows handler; . brand is e machines ..error messages,,
Hi Kate1958. I found this for you. Do one or more of the following solutions:
Solution 1: Remove all versions of Acrobat or Reader, and then reinstall one version.
If multiple versions of Acrobat or Reader are installed on the system, remove all versions and then install only one version. See the documentation included with Windows for information about removing programs.
Note: If you need to have multiple versions of an Acrobat product installed, remove all versions and then reinstall them starting with the earliest, installing the latest version last.
Solution 2: Start Acrobat or Reader, and then open the PDF file in the web browser.
If an error occurs when you try to start Acrobat or Reader, refer to Related Documents below, or search the Adobe Support Knowledgebase:
-- If you use Acrobat, go to www.adobe.com/support/products/acrobat.html .
-- If you use Reader, go to www.adobe.com/support/products/acrreader.html .
Solution 3: Make sure that the External Window Handler file (ewh32.api) is in the Plug-ins folder.
If this file is missing, reinstall Acrobat or Adobe Reader.
The default location of the Plug-ins folder is:
-- For Acrobat: Program FilesAdobeAcrobat [version]Acrobat
-- For Reader: Program FilesAdobeAcrobat [version]Reader
Solution 4: Disable Web Browser Integration.
Disable Web Browser Integration so that PDF files open directly in Acrobat or Reader instead of in the web browser.
To disable Web Browser Integration in Acrobat 6.0.x -7.0.x or Reader 6.0.x -7.0.x:
1. Open Acrobat or Reader.
2. Choose Edit > Preferences > Internet.
3. Deselect Display PDF in Browser.
4. Click OK.
To disable Web Browser Integration in Acrobat 5.x or Acrobat Reader 5.x:
1. Open Acrobat or Acrobat Reader.
2. Choose Edit > Preferences > General.
3. Click Options in the list in the Preferences dialog box.
4. Deselect Display PDF in Browser.
5. Click OK.
To disable Web Browser Integration in Acrobat 4.x or Acrobat Reader 4.x:
2. Choose File > Preferences > General.
3. Deselect Web Browser Integration in the General Preferences dialog box.
4. Click OK.
I hope this helps. Please dont forget to rate and provide positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | Computers & Internet
My system has adobe 9.1 but when i want to open some pdf it still says version 8 or 9 required
It sounds like you may have more than one version of Adobe Reader and/or Adobe Acrobat installed on your computer (not recommended) and the system is probably confused about which one to use when opening a .pdf document.
Right-click any .pdf file located on your system, and then, click Open With and then click Choose Default Program.
In the window that opens, select the program that you want your system to use when you open a .pdf file (in your case it should be Adobe Reader 9.1). It *should* be listed under the Recommended Programs section but if it is not then you will need to use the Browse button in order to located Adobe Reader on your system. If the correct program is already selected, then I suggest you unselect it and then reselect it. Make sure the "Always use the selected program to open this kind of file" check-box is checked. Then hit the OK button.
As stated earlier, it is not recommended (and not supported) for you to have more than one version of Adobe Reader installed at a time. You should do the following if the above solution does not work for you:
In Windows, go to Start Button > Control Panel > Programs > Uninstall a program
Look through the list of your installed programs for Adobe Acrobat and/or Adobe Reader. Uninstall them both (if you have more than one installed) then download and run the Microsoft Installer Cleanup Utility to remove all traces of Acrobat Reader.
Now re-install your latest version of Acrobat Reader only.
Oct 04, 2009 | Adobe Computers & Internet
Acrobat 7.1 shuts down after opening
Installing later version of Adobe Acrobat is sometime creating compatibility issue with previous installed Adobe Acrobat Pro.
Make a deep search for your condition on Adobe KB: for similar problem I had to Reinstall Adobe Pro AFTER an update of Reader free Sw.
Check this entry
Dec 29, 2008 | Adobe Acrobat 6.0 Professional for PC
MANUALS SENT AS PDF.
Adobe Reader is free to download from here:
http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html
or view online here:
http://www.pdfmenot.com/
Hope this helps
Chris (ziraffa)
Dec 28, 2008 | Samsung YP-T7JX (1GB) MP3 Player
Adobe PageMaker V7.0.2 for PC Logo
425 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
