Question about Dryers
Kenmore model 66722691 stopped heating - Dryers
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: kenmore model 66722691 stopped running. light
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 15, 2010
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Kenmore model 66722691 stopped running. light comes on timer works but wont start
heatman101
Sep 15, 2010 | Kenmore Dryers
Kenmore Dryer won't heat
Unplug the dryer.
Always remove wires to check continuity or Ohms on any part.
Remove the terminal cover where the cord connects and check all wires.
Also, check them to ground on the chassis. The only one that should read continuity is the ground wire.
After removing the wires from the heater check the heater terminals to the heat canister.
If it reads continuity it is bad.
Pay special attention to the relay on the top side of the heat canister.
Mar 04, 2009 | Kenmore 62622 Electric Dryer
I have a Kenmore electric dryer that suddenly went ''poof'' (like when a light bulb that goes out). It threw the breaker. I reset the breaker and the dryer started. I thought that was all there was to it,...
did you check the main fuse on the blower box with the wires off?also check the heater box fuse(top)and the high temp thermostat on heater box(bottom)with the wires off-mike
Mar 03, 2009 | Kenmore 62622 Electric Dryer
No Heat
go to servicematters.com
Jan 15, 2009 | Kenmore 63942 Dryer
Kenmore dryer doesnt heat
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Dec 19, 2008 | Kenmore Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
