Question about Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer
How do I rest gzip.c 422 rip error - Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer
What does it mean Dell 3010cn error code 091-422
I can only assume you mean 094-422 error. I do not think there is an error code 091-422. Anyway here is what error code 094-422 means:
The transfer belt unit must be replaced every 100,000 pages, usually along with the fuser and feed rollers as part of a maintenance kit.
The error code 094-422 indicates the belt has reached 75,000 page and as a result has 25% life or less remaining.
The belt does not need to be replaced immediately and can continue to be used until end of life is reached.
Aug 20, 2014 | Dell 3130cn Color Laser Printer
Tip
How to convert Blu-ray movies to Apple ProRes 422 codec on Mac
Thanks to its outstanding technical characteristics, Apple ProRes 422 brings powerful new capabilities to Final Cut Pro editors. It will fit flawlessly into demanding editing and effects workflows. ProRes 422 is a better choice for ensuring all creative work to maintain its original, pristine color and detail, from capture to final viewing.
However, there are seldom Blu-ray applications developed for Mac users, not to mention a program that can rip Blu-ray to Apple ProRes 422 codec for editing in Final Cut Pro. In order to make some BD HD contents into my own film works in FCP, I would like to see a straight BD conversion to Apple's PrORes 422 codec, because this codec remains the stunning HD quality and has fast decoding speed and low compression rate. However, I have no luck, and I can not find a program to achieve this goal directly without the help of third party software. Right now, I have to use Pavtube Blu-Ray Ripper for Mac to convert Blu-ray to h.264 MP4 HD first, and then convert again to ProRes 422 using Compressor. This workaround seems a little troublesome and time consuming, because a straight conversion would save me 2 hours. Following is my workflow, and how about yours? Would you like to share?
Firstly, using Pavtube Blu-Ray Ripper for Mac to convert Blu-ray to h.264 MP4 HD:
1. Click "DVD Folder" or "IFO File" to load BD files
2. Click on the pull down menu after "Subtitle" and "Audio" respectively to select your needed subtitle and audio track to convert.
3. Click on the drop-down list of "Format" to select "HD Video" > "H.264 HD Video (*.mp4)" as output format
4. Click on "Settings" button to adjust audio and video parameters
Bit rate, aspect ratio, frame rate, sample rate, and channels are all changeable in the following interface, so you can adjust them according to your own requirements.
5. Click "Convert" button to start ripping BD to H.264 HD Video (*.mp4)
Once finished, click on "Open" button to get the output files for Compressor.
Afterwards, convert h.264 MP4 HD video to Apple's PrORes 422 codec with Compressor.
The detailed steps of this part are skipped, if any of you have figured out a straight way to convert Blu-ray to PrORes 422 codec, please let me know, and any suggestion is appreciated. Thanks in advance.
For more: http://www.pavtube.com/blu-ray-ripper-mac/
on Mar 17, 2010 | Computers & Internet
My machine is showing error message F12
f12 is a error of the module not talking to rest of pcb's,, most probally needs replacing,, either do yourself quite cheaply, or get ripped off from hotpoint,,
Sep 12, 2013 | Hotpoint Ultima WF860 Front Load Washer
What to do if this is coming in between ( gzip.exe has stopped working) ?
re-install gzip if this is for ubuntu
type sudo apt-get remove gzip this removes it
sudo apt-get update
then run
sudo apt-get install gzip
this re-installs it then log off and log back in and see if you get the same error.
Jan 25, 2012 | Microsoft Computers & Internet
After reset chip printer, printer error NICBridge Gzip. c 1334 and does not edit the keys would be much help thanks.
U have wrogly upgrade d the firmware.of the main board.Try with a fresh copy of original Samsung firmware.
Elase replace main board.
Dec 22, 2010 | Samsung SCX-4828FN All-In-One Laser...
Error 900.44 .... RIP Software
The error relates to the system board / formatter.
R.I.P = Rest in Peace
Turn off machine for 10 minutes.
If error persists follow theses steps:
1. ) If the machine is networked disconnect the cable and power cycle. If the error doesn't come back up swap the network cable, with a good one.
2.) Firmware upgrade
3.) Replace the system board
Based on my experience it's either the network cable or the system board.
Oct 15, 2010 | Lexmark T642 Laser Printer
Windows Vista Premium. Trying to rip a cd to my computer. Unable to do so. CD plays fine if i play music from the cd itself. Tried Itunes 1st. Rips about 12 secs of audio for each song. Says complete....
maybe the windows has this security issues. coz from my point of view windows vista is dedicated on security. so that's why you cannot rip most of the songs very well.
Mar 05, 2010 | Computers & Internet
Ricoh aficio 6513 error code 422
this is a corona leak could be a broken or dirty corona wire
Jan 03, 2010 | Ricoh Office Equipment & Supplies
Error sc 422
I HAVE THE LASER C522 AND I HAVE PROBLEM TELL ME REPLACE WASTE TONER
Feb 10, 2008 | Ricoh Aficio CL2000N Laser Printer
Error code sc 422
422 D PCC leak
- Timing & Condition -
When the current leak is detected
for 2 seconds, leak detection
starts 1 second after the PCC
turns on. The leak signal is
monitored twice at 1-second
intervals. When the leak condition
is detected twice continuously,
this SC is displayed.
1. Check if the PCC unit is properly installed.
2. Replace the corona wire if it is broken.
3. Check if the connectors on the terminal and
high voltage supply board (T1, PCC)
are
properly connected and if the cables are
damaged.
4. Clean the receptacle.
5. Replace the high voltage supply board (T1,
PCC)
6. Replace the I/O control board.
7. Replace the main control board.
- Signals to Check -
[A258/A259/A260]
Leak Detection:
CN227-B1 on I/O control
Board
[B017/B018]
Leak Detection:
CN221-B1 on I/O control
Feb 10, 2008 | Ricoh Aficio 450 Copier
Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer Logo
492 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
