Question about Siemens RWB29
Siemans programmer will not reset after power cut
Power cut - programmer did not reset. Pilot lights remain on but programmer clock does not work. Tried to reset as per instructions i.e. by turning clock dial forward 24 hrs. The programmer remains on all the time but settings cannot be used
  • 110 Answers
SOURCE: i need the instruction manual for the siemans 4100
Check for the telephone cable(RJ11) connected to the modem. It should be without any filter of extension.
Posted on Jun 25, 2010
guru_fixya
  • 944 Answers
SOURCE: The phone rings on my
This is a normal bug which is present in 8825 model.The phone settings is corrupted,
You have to restore the phone to factory settings and set the settings whatever you like to.
Restore steps at base station:
1)Press menu.
2)Scroll to "system settings?" and press select
3)Enter the system PIN and press Select(Hope you remember the PIN)
4)Scroll to "RESET SYSTEM DEFAULTS?" and press select
5)At the promt "Are you sure" press select .the displa shows "settings reset to default" and you will hear a confirmation beep
Restore steps at Handset Defaults:
1)Press menu
2)Scroll to "Mobile settings" and press OK
3)Scroll to "Local settings" and press ok
4)Scroll to "Factory default" and press ok
5)Enter the handset PIN and press ok.The display shows "setting reset to default"and
you will hear the confirmation beep.
If you don't have the manuals click here
to download it and use it to set the ringing and tone set up.
If you forgot the Pin code you can use default pin:
Complete the following steps to reset the PIN on the 8825 back to 0000.
1. Press MENU.
2. Scroll to System Settings but do not press SELECT.
3. On the keypad, enter *65# (Star, 6, 5, Pound).
4. It will display "System PIN Reset" and return to the idle screen.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 26, 2010
  • 1891 Answers
SOURCE: KU15RA50GB - iQ100 Built-in fridge
if the frig keeps frosting then it must have a defrost problem as the nofrost ref do not have frost . i thim=nk that moving the frig is only looking like it changes things but the problem still is in the no frost system .. mm
Posted on Sep 01, 2010
Macmarkus
  • 2605 Answers
SOURCE: My dishwasher won't switch off
Welcome to FixYa.
Based on your description
I'd say the issue actually is with the control...unfortunately. This is commonly associated with a heating fault on Bosch built dishwashers ( various models including Bosch, Thermador, Siemens, Gaggenau, and Neff ).
Since the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
These are the steps you'll need to follow to resolve it or at least investigate.
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e. ( this may differ from your specific model, but the same rules apply )
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last.
Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Feb 26, 2011
diodeic
  • 1622 Answers
SOURCE: My Siemans 8825 failed.
Hi, to make it easy for you, let me show you how i did mine through the link below...It helped a lot.
You can try and see your self and give me a feetback..ok
http://www.barclayent.com/Cordless/siemenscordless.htm
Hope it helped.
Posted on Apr 18, 2011
Multi purpose oven won't work after power cut have reset clock, light won't work. Is making all the right sounds just won work
power supply from clock damaged not by power cut but voltage spike when power resumed the oven thinks its in auto mode permanentley thats why it wont come on ,new clock or power board needed.
Feb 03, 2017 | Neff Ovens
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Why the clock on the cobra 29 lx keep cutting out
jay I am not sure what you mean by the clock cutting out. I enclosed the manual in PDF form look at page 17 and see if this helps. If not ask the question with more detail.
https://www.cobra.com/sites/default/files/manuals/29%20LX.pdf
Oct 05, 2014 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not...
Hello
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
OK.
Jul 10, 2011 | RCA Rc40 Clock Radio
Unit ( model SR142gp serial 0608MA0448 - propane fuel ) operates as designed, but can not cut flame to pilot with the thermostat. must cut the gas control to pilot to the get pilot flame & pilot...
The pilot light should remain "ON" all the time. It is not intended to ever go off, unless you are not going to use the fryer for several months at a time. Then you can just shut off the propane which will shut off the pilot light flame. It does not cost that much to run the pilot light all the time. About one to two dollars a week.
Sep 11, 2010 | Frymaster Dean SR142GP001 Deep Fryer
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
A (automatic cooking)remains in the digital reader which means that the electric oven/grill and fan oven won't work. It will not clear from the box.
What happens when you turn the power off to the whole oven, leave it off for a few mins and then reapply? If the automatic is still set it could be the clock is faulty.
Have you tried resetting the clock as per the handbook?
Dec 01, 2009 | Stoves 720EF Electric Double Oven
Oven has power but will not turn on. Cannot set
try to cut the power to the oven for about 30 minutes and see if it will reset the clock. if this doesn't work you may need to replace the ERC (clock). sometimes you can get a rebuilt, check around.
Oct 11, 2009 | Ovens
Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Jan 20, 2009 | Water Heaters
Power cut and now cant reset the clock
We flipped off the designated breaker to the oven and turned it on again. We were then able to reset the clock. This has happened to us several times.
Apr 21, 2008 | Fisher and Paykel AeroTech Double OD302...
Siemens RWB29 Logo
208 people viewed this question
Top Siemens Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Siemens Heating and Cooling Expert? Answer questions, earn points and help others
