Question about IOGear Wireless 4Port USB Sharing Station GUWIP204 (Black
Software install will not complete
Install of software completes, then a box shows up the "control center installation did not complete, Please reinstall"
  • Edward Vetalice
    Edward Vetalice Nov 11, 2012
    Some additional info: The software for this wireless 4 port sharing station is installed on two windows 8 computers. A laptop, which works fine, and a tower PC. The tower is the computer having the problem, checking the install, shows me that the Control Center has installed fully as far as file size is concerned, when compared to the laptop . I have removed and reinstalled several times , getting the same results and error message.
While updating ma nokia 6303 classic mobile software net connection disconnected...after that my mabile is not at all working...donno wat to do....
That means software is not installed completely to install complete software you must use Software Dongle's Like e.g JAF Software Dongle, UFS Software dongle, using thouse dongles you can install mobile software. instructions Please do it if you are a Mobile technician then only try to do this if you are not Mobile technician the dont try this.
If you are not a Mobile Technician then Please Visit your Nearest Nokia Service Center (Nokia Care) or Visit Any Mobile Repair Center they will install the Full Software.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up &
Testimonials //
Jun 28, 2011 | Nokia 6303 Cell Phone
Tip
Fatal error : HPZPRL01.exe while installing HP printer Software
1. Perform System restore:
If the printer software was previously installed on the computer anytime before or even if the original issue was anything else before this error, then try restoring the computer to the date on which the software was working. You can then do add a device from the installation screen. The printer would start working fine as the software would already be available after doing a system restore.
2. Uninstall the complete Software.
Perform L1, L2, and L3 uninstall. Then reinstall the s/w.
3. Insert the CD & start the install, select custom install.
Under options select only "HP Drivers (required)" in order to install only the print/scan/fax drivers. If drivers will be successfully installed, you can add one by one the HP software starting again the installation and selecting Install More Software button & install the software in this order:
• HP Solution Center
• HP Device Functions
• OCR Software
Do not install HP Participation Program or HP Customer Experience or HP Supply.
4. Grant full permission to the system
Right click on My Computer, go to properties\security\Group or user names\ select the customer’s user name & click on permissions. Click to select the Full Control check box under Allow, and then click Advanced. Check both the boxes under advanced window. Click OK & close all the windows & restart the PC. Install the software by following customer install method.
5. Make sure that you have write access rights enabled for the following registry keys:
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors\
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2\
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Print Processors\
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Prrint\Printers.
on Jul 03, 2010 | Office Equipment & Supplies
FATAL ERROR HPZPRL01 while installing the printer software
• OCR Software
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Printers.
In order to provide the write access, right click on the folder and click permissions. In the permissions window select the customer’s user name or ‘Everyone’ and give a check mark for full access.
Then install the drivers again.
all the best
Mar 10, 2010 | Office Equipment & Supplies
"No scan options, refer to devise docs."
Hi
I have provided the troubleshooting doc, please follow this to resolve the issue.
Solution:
Follow these steps in the order presented to resolve the issue.
Step one: Verify that the Digital Imaging Monitor is ready
The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete.
If the Digital Imaging Monitor is in the system tray, proceed to Step two.
If the Digital Imaging Monitor does not appear in the system tray, follow these steps.
Windows 98, Me, and XP
1.Click Start , and then click Run .
2.In the Open text box, type msconfig .
3.Click OK .
4.In the System Configuration Utility window, click the Startup tab.
5.Search the list for HP Digital Imaging Monitor .
6.If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. 7.Proceed to step three to uninstall and reinstall the software.
8.Select the HP Digital Imaging Monitor check box.
9.Click Apply , and then click Close .
10.Click Yes to restart.
Windows Vista
1.Click Start .
2.In the Start Search text box, type msconfig and press Enter .
3.On the User Account Control window, click Continue . The System Configuration Utility window displays.
4.Click the Startup tab.
Step two: Populate the destination list
1.The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
2.Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
3.On the Windows desktop, double-click the HP Solution Center icon.
4.On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
5.If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
6.Click Settings .
7.Click Scan Settings and Preferences .
8.Click Scan to... Setup .
9.Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
10.If the Front Panel Destination List is empty, continue with this procedure.
11.If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
12.Click each program to include on the Scan To list.
13.Click the Add arrow.
14.Click OK .
15.Scan a document using the Scan To button on the front panel.
16.If the scan fails, try to scan using the HP Solution Center Scan button.
17.If the scan still fails, proceed to Step three to uninstall and reinstall the software.
Step three: Uninstall and reinstall the software
1.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
2.If the software installer does not automatically start, complete the following steps.
3.Click Start , and then click Run .
4.In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
5.Click OK .
6.On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
7.Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
8.If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
9.Follow the onscreen instructions until the printer software is completely installed.
10.After successful installation, scan a document.
Step four: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Thanks
Riz
Jan 14, 2009 | HP OfficeJet J4580 All-In-One Laser...
My new hp officejet pro L7590 printer tells me that "no scan options" are available. I bought this as a all-in-one printer. help, I need to scan
Hi Kate,
This error occurs if HP drive services are not functioning properly, so try my solution
Solution
3.Click OK .
Windows Vista
1.Click Start .
6.Click Settings .
14.Click OK .
5.Click OK .
Thanks
Riz
Jan 13, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
When I hit scan it says "no scan options"
Hi just follow the below steps and the problem will be resolved.
Solution:
3.Click OK .
Windows Vista
1.Click Start .
6.Click Settings .
14.Click OK .
5.Click OK .
Thanks
Riz
Dec 28, 2008 | HP Officejet J5780 All-In-One InkJet...
No Scan Options
Hi
i really understand your concern.I have a document that i prepared to solve this particular issue.This will help you alot
Solution
3.Click OK .
Windows Vista
1.Click Start .
destination list.
6.Click Settings .
software.
14.Click OK .
5.Click OK .
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 09, 2008 | HP OfficeJet 6310 All-in-One Printer...
Scanner doesnt work
Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig .
  3. Click OK .
  4. In the System Configuration Utility window, click the Startup tab.
  5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
  6. Select the HP Digital Imaging Monitor check box.
  7. Click Apply , and then click Close .
  8. Click Yes to restart.
Windows Vista
  1. Click Start .
  2. In the Start Search text box, type msconfig and press Enter .
  3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
  4. Click the Startup tab.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  2. If the software installer does not automatically start, complete the following steps.
    2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
    3. Click OK .
  3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
  4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
  5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
  6. Follow the onscreen instructions until the printer software is completely installed.
  7. After successful installation, scan a document.
Step four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 14, 2008 | HP Officejet J5780 All-In-One InkJet...
I am trying to scan a pic and my scaner says no scan options
  3. Click OK .
Windows Vista
  1. Click Start .
  2. Click Settings .
  9. Click OK .
    3. Click OK .
Jul 08, 2008 | Office Equipment & Supplies
IOGear Wireless 4Port USB Sharing Station GUWIP204 (Black Logo
93 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
