Question about Whirlpool Refrigerators
Ice maker is leaking on my whirlpool golf side by side refrigerator
Ice maker is overfilling. What controls the amount of water that is put into the ice maker?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 07, 2012
Ice maker leaking water and freezing in the freezer (ice-cycle forming)
The solenoid controlling the amount of water entering the tray is not shutting off properly and overfilling it.
Jun 25, 2015 | Whirlpool 22 cu. ft. Side-by-Side...
Whirlpool refrigerator water dispenser not working
hve u tried to clean any blockages in the unit.let me know wat other problem u face
Oct 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Water overfilling the freeze tray on Whirlpool conquest ice maker
The overfilling is most likely caused by defective water control valve on the ice maker side. The replacement for your model is a=> W10408179 Water Inlet Valve
The water fill adjustment can be found in the Ice Maker Troubleshooting Service Manual These settings can cause too little or too much by turning the set screw so use caution. I will be here should you have questions or comments, Thanks Sea Breeze
Mar 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker leaks
What is the model number of your unit?
Nov 06, 2012 | Whirlpool Refrigerators
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Overfilling ice tray with water
Does the water eventually stop flowing? If not, your solenoid valve is sticking open and defective. If you also have ice and water through the door, this is a dual solenoid valve. If it does eventually stop, your ice maker could be sticking in fill mode. Either way this could be a potential for a flood. I would recommend replacing both.
Dec 01, 2008 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
37 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
