Question about GE Washing Machines
I am still working on my GE WCSE4160B1WW top load washer. The agitator will not move during the wash cycle. I thought it might be the agitator coupling, but the agitator will not move or spin with I
I know how to disassemble the washer, but I'm not sure what to look for. I guessing a transmission or drive assembly because I hear the motor. Any suggestions?
  • Pat Ryan Nov 09, 2012
    Could the problem be the motor coupling?
fanny
  • 146 Answers
SOURCE: Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Posted on Oct 31, 2007
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
MrJuanDerful
SOURCE: Agitator Not Working
My Hotpoint VBXR1090B top loading washing machine quit spinning during the rinse cycle and also quit agitating. The water filled up and drained just fine --no leaks.
Here's how I fixed it in 5-minutes.
Tools:
  1. Putty knife
  2. Nut driver - I used a multi-purpose screwdriver without any heads attached.
Procedure:
  1. Unplug washer from the electrical outlet for safety
  2. Release two spring clips holding the front panel on: Insert a putty knife 5" in from the side between the top and the front panel. Pull the front panel forwards.
  3. Unscrew 2 screws holding the top down.
  4. Lift top - it's somewhat hinged in the rear with three tabs inserted in control panel.
  5. The little red tab at the end of the lid switch should be between the lip of the opening and the top; not sitting on top of the lip as mine was.  It's thin enough steel to push it with your bare hands.
  6. Make sure when the lid closes it actually causes the switch to turn on. You should hear a click.
  7. Put everthing back together. Plug washer back in. Put your tools away.
  8. Voilà. Done. Easy.  Even a woman or a ****** could do it.
Posted on Apr 26, 2009
  • 7 Answers
SOURCE: Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Posted on May 05, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
Washer does not spin but water goes out. Agitation does occur during wash cycle. Belt is in place and does move when pulled. When turning the agitator the tub moves. What would need replaced?
Motor will not turn the one way...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 19, 2010 | GE Spacemaker Washer and Dryer Electric...
Hi, The water comes into the load, but then their
the agitator shaft could be stripped out. does it sound like the motor is working during the wash cycle or is it just idle? This is a common problem with ge washers the agitator strips out on the transmision and needs to be replaced.
Jan 02, 2010 | GE WJSR2070B Top Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
GE top loading wash machine makes noise during agitation cycle...
look in your basket of washer see if you see anything stuck in the hole ok
Oct 20, 2017 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
GE washer WJSR4160G0WW agitation is way too fast & hard
check the 4 rubber cords at the top of the tub. If the washer has been moved they may need to be adjusted, you can see them by looking between the top of the tub and the top cover. You can turn them with your hand, and you may need to tighten them after.
Jun 07, 2009 | GE WJSR4160DWW Top Load Washer
GE TOP LOADER DOES NOT AGITATE DURING WASH CYCLE BUT DOES SPIN DURING EXTRACTION
Remove the agitator and check the agitator splines also the agitator coupling on the shaft may be stripped.
Feb 21, 2009 | GE WBSR3140DW Top Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
37 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
