Question about Refrigerators
Why on earth have you changed the shells on vice versas'?
They taste like **** now
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What are you talking about?
Posted on Nov 07, 2012
Reverse is forward and vice versa
To get a dc motor to spin in reverse you have to change the polarity of the battery. This is normally done in the switch by which set of poles is connected . Have you connected the battery up correctly in the first instance.
Jul 13, 2013 | Minn Kota Endura 40 Transom Mount Trolling...
2002 buick lesabre spits sputters voltage jumps
check you have good earthing points, also check the earthing strap from engine to shell. main earthing point follow the negative lead it will go to the shell.
Jul 26, 2017 | 2002 Buick LeSabre
The dimmer switch on my 1999 firebird won't change the headlights from dim to bright, or vice versa. It has a good click to it and the blue light in the dash comes on when they're supposed to
That is a common problem, the switch needs changing if the high and low beams do work, the only problem is that it's an expensive part to replace, try a local wrecking yard they should have a bunch of suitable replacements at a reduced price.
Sep 19, 2012 | Pontiac Cars & Trucks
Click when changing screen size
some models have clicking sounds when change that but some are not..
Don't worry its normal as long as it can't affect the picture and sounds
Thank you
regards,
chester.
Jan 19, 2012 | Toshiba 42HP95 Television
My new amana dryer died and the repair people said there was moisture in their which must of come from the dryer vent and blew it. I had the dryer vent and builders of the building inspect the vent system...
Is the vent connected to another dryer as well? I've seen this before. Builders will sometimes put in a vent and have 2 dryer venting into it. The second dryer will send moisture into the first one and vice versa. Also, check for baffles on the outside vent. If cool air is coming into that vent then it will cause condensation in your dryer.
Aug 04, 2010 | Dryers
2005 Jeep Liberty Sport. Headlights. Passenger Side is dim
TEST
remove both bulbs from the lamps but leave them on their wires switch on and see if the bulbs are still different brightness if not they the passenger side lamp housing has damaged mirror is dirty or missalined and needs adjustment. if they are different brightness then this may be a earthing problem.
Nov 13, 2009 | 2005 Jeep Grand Cherokee
Cycle timer displays very different times for cycle, cleaning is not particularly good. Problems related? glasses appear filmy, even when rinse agent is used.
your dishwasher uses an optical sensor to constantly monitor the water turbidity or cleanliness if it detects the water is cloudy it will extend the wash time and vice versa there are several reasons for cloudy glasses check to see if they taste salty,or if the cloudiness washes off,this usually happens when the baskets are loaded badly and the detergents/temps are not set correctly.
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Air compressor kicks on but fan doesnt and vice versa
I assume you mean the condenser fan motor ? Try to manually spin it. If it is hard to turn, change the motor. If it spins freely, change the capacitor.
Apr 26, 2009 | Heating & Cooling
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
