Question about Toshiba Televison & Video
Cant record,stating weak signal.
Programmes are ok to view,but when i try to record,weak signal appears.set top box is hitatchi hddr 082.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
May be the box or a poor connection or cable---check those first and if possible try the box on another set.
Posted on Nov 07, 2012
SOURCE: Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
Posted on May 08, 2010
fosg2000
  • 229 Answers
SOURCE: samsung lnr406d tv won't turn on. clicks every 20
well probably you have a faulty power supply do this :
>undo the back >look for buggy or burned capacitors in the POWER SUPPLY *this model has two power modules (Main + Sub) >when find the bad capacitor replace it.
just in case that you need the parts numbers of the power supply's are those :
> MAIN : BN41-00521B > SUB : BN96-01805A
you can get online just google it
Please Rate me !
Fosg'2000
Posted on Aug 10, 2010
  • 89 Answers
SOURCE: I cannot get my DVD
My take is that you probably should consider sending it back if you can. The first point in the reveiw below answers your question I think. There are several complaints there. I took the following off the Amazon website UK - apologies to the writer:
By N. Adams "Analogue Design Dude" (France) - See all my reviews This review is from: Samsung DVD-SH893 160GB HDD Recorder - Black (Electronics) This certainly the biggest disappointment I've ever had when buying a HiTech item.
Although it does (almost but not quite) all the things claimed, the user interface
is so terrible that I get annoyed every time I use it (every day !). I almost wrote
to Samsung to ask if I had a Beta version of the software, but I never did. I can now
at least try and warn others...
The stupidities are too numerous to mention, but here is a shortened list:
**When you have a timer recording set up - it will not start to record if the unit is
still switched ON (is this software from a VHS recorder?). You can record something
and watch something else as well (small mercies!) but the recording (or timer) must
be already running before you press play - or no deal.
**The Marker system is almost unuseable because you have to remember which marker number
corresponds to which recording. Just to make the game more interesting - when you
erase something that is Marked - the other Marker numbers shuffle around !
**The editing system is nightmarish, and you cannot use Markers that you placed during
previous watching. Gone are the days with my Panasonic where I would watch a film,
"Chapter" the adverts - then all the edits were done before writing to DVD. Even if
you know that a film is so many minutes long, there is no way to jump to that point
during the editing process. You have to watch the program run through ( at x64 max )
and wait.
**You cannot choose the recording speed (SP/LP etc )to HD when you are using the internal
tuner. Also you cannot record to DVD at a different speed than the HD recording !!!
This means that where I always put two films on one single layer DVD in LP, now I can't.
Well that's enough moaning - I hope it puts you off considering this horrible device.
Even though I've only had mine for about 5 months I think I'll treat myself to Christmas
present of another HDD recorder !
Posted on Nov 30, 2010
  • 11800 Answers
SOURCE: My TU500 DTR has worked
This Bush unit is made by Vestel - a chinese manufacturer "renowned" for the miserable quality of its products. In your case the encoding processor (the one that encodes the data in avi format and puts it on the hdd) has failed. This is a terminal problem - the only way to fix it is to replace the mainboard and that would cost more than what the unit is worth.
Luckily your unit is still in the warranty so take it back to the ones that sold it to you and let them deal with it - most likely they will replace it. Do not open it or you will lose the warranty.
Posted on Dec 06, 2010
  • 159 Answers
SOURCE: I recently purchased an LG
Hi, The set top box will more than likely have two coaxial connectors ( threaded/ribbed pieces of metal ) coming out of the back. also three R.C.A. connectors-these will be smooth and be colored yellow red and white. one of the coax connectors will say " IN FROM ANT> or CABLE IN) the other ( OUT TO T.V. ) hook up your dvd recorders " ANTENNA " input to the set top box's ANTENNA output. If your D.V.D. recorder doesn't have an antenna input then hook up the recorders audio/video input to the set top box's audio/video output. then you should be good to go. If you buy a H.D.T.V. tuner to receive FREE H.D. programming it may be possible to hook up to recorder with H.D.M.I. cables.( those connections resemble slots ) I hope this has been of some assistance, good luck, Prodzilla.
Posted on Apr 02, 2011
No signal appears every few minutes on all programmes. Is ok with Foxtel
if you do not have an antenna hooked up and change the input . this will always happen .
Dec 07, 2015 | Televison & Video
Problem with watching normal scheduled TV and recording programmes
If you have an indoor antenna connected to that particular TV, a slight reorientation can make a big difference.
Oct 25, 2015 | Humax Televison & Video
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
Dec 05, 2010 | LG MG64 VHS VCR
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
The thompson DV3 250 has deleted all my saved recording as 'invalid programme removed' it states the recording became corrupt on boot. the box has not been re-booted. and now it does not allow any...
No thank you.
This appears to have been a corruption caused by Top-up TV. The set box has been re-set to factory mode and re-booted
Thanks
Jan 19, 2010 | Televison & Video
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Televison & Video Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
