Question about PlayStation 3D Glasses
Playstation 3d glasses won't turn on
They won't even charge, i've switched the cable and everything and still nothing
2004 Mercedes c240 won't start, turned the
It is located on the transmission where the sghift cable connects to the transmission.
Jun 12, 2013 | Cars & Trucks
Won't start
How about corroded battery cables (internal)
Fusible Link wiring corroded & open circuit,does
everything electrical work except the starting circuit?
Turn key & have power to starter solenoid ?
Neutral Switch !
Ignition Switch !
Tough to guess without wiring diagrams,
to see where to start testing
Can't fix what you don't know you have
Oct 02, 2012 | 1990 Ford F150
Philips DCB146 NO SOUND!!
The answer is straightforward. The main power amp has gone. If you are lucky it's a single IC unit which you will find on a big heat sink. It might look like the one shown below.
You will of course need to de-solder it and resolder a new one. The type needed to replace it will be shown by the letters and number on the IC itself.
May 02, 2017 | Audio Players & Recorders
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
Just moved into this house, with a warnock hersey gas fire wh3990 removed the glass for cleaning now it won't come on .I think I disturbed the log placement ,it has a temperature control but even...
When you replaced the glass, you may have not made contact with the glass safety removal switch. In which case, other than the pilot, nothing else will work. When you cleaned the glass, I hope you didn't use a commercial glass cleaner. As they have ammonia in them and it leaves an invisible residue on the glass. When it heats up the residue will turn white and stay on the interior of the glass. If you did use a commercial glass cleaner, remove the glass (which you're going to have to do anyway) and clean it with a 50/50 solution of vinegar and water. Then dry the glass thoroughly with paper towels.
The glass safety removal switch is generally at the bottom of the firebox opening right under the glass, In fact the glass will rest on it. Once everything is cleaned (if necessary) and reassembled. Be sure that after the pilot is lit, the gas control knob is turned to ON. If you have a wall switch that tunrs the burner ON & Off, it will now take over.
Hope this helps you and thanks for choosing FixYa.
Sep 21, 2011 | Heating & Cooling
1995 geo tracker won't start. I've replaced everything except the ignition switch. It used to click when i turn the key, now it won't even click.
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
HOPE THIS HELPS!
Aug 30, 2011 | Geo Tracker Cars & Trucks
PlayStation 3D Glasses Logo
136 people viewed this question
Top PlayStation Video Game Consoles & Games Experts
James Wishart
Are you a PlayStation Video Game Console and Game Expert? Answer questions, earn points and help others
