Question about Arris SB6121 SURFboard DOCSIS 3.0 eXtreme Broadband Cable Modem (612572180136)
FLASHING AMBER INDICATOR LIGHT ON A SB6121 MOTOROLA MODEM.
WHEN I HOOKED UP A BELKIN N6000 WIFI DUAL-BAND N+ROUTER TO MY SB6121 MOTOROLA MODEM, THE MODEMS AMBER LINK INDICATOR LIGHT STARTED FLASHING, AND I WOULD LIKE TO KNOW WHAT THE FLASHING AMBER LINK MEANS.
  • 1015 Answers
SOURCE: New modem will not work with my Belkin F5D7230-4 router
I would start by re-setting the modem. Disconnect the power for the router and modem. Wait a minute or two. Plug the modem back in first. Wait for the modem to complete communication with your internet service provider. When all communication lights are good on the modem then plug the power into the router. It amy take a few minutes to get all the lights. Hopefully this will allow the DHCP to release from the old router and renew to the new one. Make sure if your internet provider requires any manual configurations that they are properly configured in the new router.
Posted on Sep 12, 2009
  • 86 Answers
SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
Posted on Jan 20, 2008
SOURCE: Need to hook up Belkin G wireless router to Motorola SB5120
I have a Motorola SB5100 Cable modem and i have a belkin N wireless ROuter..i have conncted the wire from modem to router and computer to router and it doesnt work??what do i have to do??
Posted on Feb 26, 2008
djxtreme979
  • 151 Answers
SOURCE: Switched to cable(arris modem) can't set up network
cable dsl same thing. Did you switch providers and get new modem from them? If so. Just delete previous netowrk and install new one let pc discover new one. Also, with your router you got a disc. It should install correctly. Perhaps it is previous network that is hindering you.
Posted on Dec 30, 2008
ohms
  • 1879 Answers
SOURCE: ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Posted on Jan 26, 2009
How can I connect?
Here is a link to your extender"http://cache-www.belkin.com/support/dl/MAN_F9K1111v1_8820-01079_RevA00_N300_RangeExtendr%20%282%29.pdf".
Mar 29, 2016 | Belkin N300 Dual-Band Wireless Range...
How do I find the bridge mode in sb6121
The Motorola Surfboard SB6121 is a cable modem only - no router included.
You must have a router - after the modem - in the network if you need router duties.
There is no bridge mode in the modem. Bridging the modem basically bypasses the routing function of the device and passes everything on to the next device in line......the router in this case.
Since this modem does not have a router built in - it is always in bridge mode.
Feb 03, 2015 | Arris Sb6121 Docsis 3.0 Cable Modem...
Need manual.. Cannot access internet..modem indicator stays orange
Per chance have you looked on YouTube for a video on how to hook up this particular router: Generally they have a video for just about anything imaginable. Good luck!
Jul 28, 2014 | Belkin N750 DB Wireless Dual Band N Router
SURFboard DOCSIS 3.0 boosting the wifi signal
The SB6121 doesn't have WiFi, but I used a wifi extender (~$40-$80) to boost the wifi signal of my current wireless router that's attached to the SB6121.
Sep 20, 2013 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
FLASHING AMBER LINK IDICATOR LIGHT ON MY SB6121 MODEM
The SB6121 link light uses color to indicate the connection speed. Blinking means data transfer is taking place. Blue means that it's a 1000Base-T (High-speed Gigabit Ethernet). Amber means it's an older ethernet device. 100Base-T or 10Base-T Ethernet connection.
Nov 06, 2012 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
Amber light flashing on belkin 150 router
Disconnect the ISP modem power and network / cable. Do the same with the router. Wait a few minutes and reconnect starting with modem.
Oct 08, 2012 | Belkin Connect N150 Wireless Router...
Bottom lights flashing amber
Try just unplugging the router for 20 seconds then plug it back in.
Jun 07, 2012 | Belkin (F5D8235-4) Wireless Router
And orange bliking light came on what does it mean
If your belkin wireless router is flashing orange, it more than likely means it was hit by a power surge or got wet and popped the circuit on the mother board of the router. Took mine apart and found where the circuit had been blackened by power surge hitting it. I was able to salvage one important thing was the antenna that can be adapted to other systems if you know what your doing.
Dec 12, 2010 | Belkin Surf N300 Wireless Router...
Wireless amber light flashing problem
If the wireles light is flashing Amber .. Some one outside your house is trying to access the Wireless network . If it is always flashing amber.. try with a Firmware update available in belkin.com/au/support.
Thank You
Jul 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Arris SB6121 SURFboard DOCSIS 3.0 eXtreme Broadband Cable Modem (612572180136) Logo
1,359 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
