Question about Food Mixers
Leaking smeg kitchen mixer tap - Food Mixers
SOURCE: Kitchen Aid Classic Mixer
I have this problem too -it is rather common if you search the web. There was a suggestion posted on this site about what to do. See http://www.fixya.com/support/t125253-mixer_leaking_oil I have also read about other people taking it to a Kitchen Aid repair place where they repacked the grease for about $45. I took mine apart and there is gobs of grease around the gears. Right now I am still trying to figure out what to do. I am going to have my father look at it to see what he thinks since he is good with motors. The Kitchen Aid web site says that the grease is FDA approved, so at least it's not going to kill you if a little gets in your food. Their suggestion is to take it out and run it for about 5 minutes at least once a week. They say it leaks if it is not used often enough. That logic doesn't make much sense to me, but you could try it. Mine seems to leak more when I run it because the grease heats up and liquifies more. I hope that helps. I'll let you know what happens with mine, once it's fixed. Lisa
Posted on Jan 19, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: blade won't release from mixer
To Remove Flat Beater, Wire Whip or Dough Hook
1.
Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft.
If the beaters are stored on the shaft of the mixer when not in use, food traces can harden and make mixer attachments difficult to remove. Should this occur, wrap a hot, damp towel around the shaft to heat and expand the area. A small amount of cooking oil sprayed around the shaft may also help. After the beater has been removed, thoroughly clean the beater shaft area with a small brush to remove any food residue.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
  • 72 Answers
SOURCE: targa kitchen sink chrome mixer tap. circa 2002.
Contact the manufacturer and they will post a replacement which screws into the tap.
Posted on Dec 27, 2009
farmerbear
  • 490 Answers
SOURCE: My kitchen mixer tap is dripping from the handle.
almost certainly yes. It is most likely the packing or the handle gaskets. Depending on the brand, there is most likely a kit waiting for you at any decent hardware store. If you tell us the brand and type, we can direct you to the most helpful options. I am a great proponent of DIY, so carry on! :)
regards,
Farmerbear at FixYa.com
Posted on Sep 13, 2010
SOURCE: How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Posted on Aug 19, 2011
My wifes Kitchen Aid ksmc50 (rrk90) mixer leaks grease/oil from the rotating plate that the beater/dough hook attatches to.The grease/oil leakes from around the outer edge of the plate as well as from...
the rotating plate needs to be pulled of and clean the grease out and only put two teaspoon dabs on ether end. to pull it of you will need to push the pin in the middle out and just lightly tap it back in.
Feb 15, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Leaking fluid, oil I think around the kitchen aid ring
Bucksmom, Sorry to hear you mixer is 'leaking'... I hate it when that happens. You don't mention how old or what model your KA mixer is? I assume you mean the band around your mixer with the Kitchenaid logo, when you say 'kitchen aid ring.
Your mixer does have an internal gear mechanism (transmission if you will) which converts the electric motors rotation into the mixer rotation and those gears are located within the mixer. The gears were lubricated at the factory, but depending on the age of your mixer and how it is used, it is possible that the grease has leaked beyond the gasket and that is what you are seeing now.
It is possible to disassemble the mixer to determine where the grease is coming from and troubleshoot if anything else might be wrong within the transmission.
Hopefully the leakage is not getting into your food being mixed. Kitchenaid Grease should be 'food grade' grease, but you still don't want to ingest it.
I hope this helps... Howard, Burke, VA
Nov 01, 2009 | KitchenAid Food Mixers
Oct 05, 2009 | Food Mixers
Kitchen aid--heavy duty mixer
The beater is held in place by a pin and spring arrangement. Lift and twist the beater. If that doesn't work, the pin is trying to come out...and is wedging against the beater. Tap the pin back in a bit, and the beater should release.
Regards, --W/D--
Jul 25, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid mixer leaking yellow oil is it repairable it still tu
It can be. This may require replaing the plate that the shaft comes through, since there is now enough play to allow the grease that is in the nead to leak through. You can find the parts online, but be ware, it involves tapping out pins and undoing many screws. Manuals are available online at Kitchenaid.com
Jan 24, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Leaking oil at the base
A TV show "How it is made" was in the Kitchen Aid factory and they used a thick grease and no oil in the mixer. Does your unit get hot? Maybe its melting the grease (dark brown)..
Oct 25, 2008 | KitchenAid KP2671 Professional 6 Series...
Dec 24, 2006 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
71 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
