Question about Onkyo TX-DS747
Looking for a good amplifier
Hey!
I have picked up a bose 901 speakers in India from a person leaving back for the states.
I am in search of a good amplifier to enjoy the beauty of the speakers. The person from whom I purchased it had a Pioneer amplifier and was not keen on selling it to me as it was over 10 years old.
Can you please suggest a good amplifier for the same please.
Regards and Best Wishes
Anand
P.S.- I am more of a music buff would prefer for music only and not for watching movies.
    Brigadier General:
  • 8,546 Answers
Any 2-channel (or greater) receiver or integrated amp with at least one Tape Monitor loop; or any separate amplifier - will work. I would look fror one with true > 100 watts per channel, all channels driven, 20-20000kz + a few dB, with less than 0.5% Total Harmonic Distortion (in other words clean and powerful) should suffice. Specific brands don't matter. I'm partial to old Carver amps.
However, should you get a multi-channel amp for the 901's you will be limited to using only 901's on it as the required Active Equalizer would affect all speakers attached to the amp, and conventional speakers would not sound right and could possibly be harmed by it's drastically-altered frequency response. Since using the Tape Monitor on modern DSP Receivers disables their digital inputs, that would limit what you could listen to, should you later decide to go with Cable Box, DVD, SACD, DVD-Audio, Blu-Ray, DTS etc.
* There are no some multichannel receivers out there that allow separating the preamp-amp circuitry for each channel to allow for differences in speaker processing. I think Marantz had one.
However, having a 901-based multichannel setup myself, I would highly recommend getting the Full Monte for video listening (below)...
In that case a separate stereo amp for the 901's would work. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
So to sum it up, I think you should start with a powerful, clean amp with few bells and whistles for the 901's and maybe later add a multichannel receiver with all the magicfor source control, DSP and to drive the other channels.
Posted on Apr 25, 2009
  • David Dunn
    David Dunn Nov 30, 2009
    was the post above helpful?
Bose 901 equilizer connections to sansui G901DB
It sounds like you may have only the 901 loudspeakers, and not also the companion 901 equalizer box. You must install the 901 equalizer properly--using the tape monitor loop of the G901 receiver. If you of not, the 901 loudspeakers will perform poorly.
Jun 17, 2014 | Bose 901 VI Main / Stereo Speaker
`Which ampliphier is compatible for my Bose 901 series 6 with equilazer.
Ideally, an amplifier or receiver should have either a "Tape Monitor" selector switch and Tape Input & Tape Output jacks, OR have Preamp Output & Amp Input jacks to enable insertion of the Bose Active equalizer into the circuit before the amplifier stage. Power requirements - according to the 901 Series VI manual:
"Your 901 speakers are designed to work compatibly with receivers or amplifiers rated from
10 to 450 watts per channel."
If you have questions not answered by the manual, you can contact customer service at The Bose Corporation in Framingham, MASS toll free at:
1-800-999-2673
Hours of operation:
7 AM - 2 AM ET, 7 days a week
I hope this helped & good luck!
Nov 22, 2010 | Bose 901 VI Main / Stereo Speaker
Bose 901 series 6 equlaizer problem
Only a careful experiment with steadily increasing volume would reveal the answer. Or measure the resistance of your cobbled work to see if it sufficiently high to avoid amplifier stress.
Original Bose 901 drivers in many series' are available on eBay and other places. I would NOT mix drivers within an enclosure. They should all match in every respect. Bose typically uses some very low impedance that totals to 8-ohms as wired inside.
There are many 'golden ears' who have used 901's without the Active EQ at all or improperly configured and they have been happy with the sound. Sonic beauty is in the ear of the beholder.
I would NOT forgo the EQ.
Jul 11, 2010 | Bose 901 VI Main / Stereo Speaker
What niles power amplifer would work effortlessly with my bose 901 speakers? i am trying to achieve a deeper bass and tonal level treble for my speakers even at a low volume levle thanks.
The 901 Active Equalizer comes with some bass and midrange adjustment for tayloring them to your environment and taste.
Your question is about personal preference, which none of us could possibly answer.
Since any amplifier worth its salt should just make the sound BIGGER without coloring it, your question is moot. What you want is NOT a quality amp. Maybe an equalizer?
Mar 21, 2010 | Bose 901 VI Main / Stereo Speaker
Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
Hi to double check
Not sure what you're asking. Can you restate the question with no typographical errors?
I can think of no reason why Bose 901's and this, or any, good amplifier would not be a good match as long as you have the Type VI Active Equalizer that goes with the speakers. I would connect the Active EQ where the Pre Out2/Main In jumpers are.
Mar 10, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 series V speakers
use a dedicated amp for ur 901s..and like the guru said,if ur doing multi channel amplification,just get ur front signal from ur control amp and feed it to ur 901 amp through the 901 eq.i used to work for bose as a service tech here in okinawa ,japan.
Feb 08, 2009 | Bose 901 VI Main / Stereo Speaker
What kind of amplifier and other accessories are recommended for bose 901 speakers
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
Dec 22, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Nov 28, 2007 | Bose 901 VI Main / Stereo Speaker
Onkyo TX-DS747 Logo
250 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
