Question about Sewing Machines
Thread keeps breaking on Babylock BL600
I thread my machine correctly but when I thread it on the first loop at the bottom and come back up, it keeps getting caught in this area beside a spring and the spring moves up when I sew and it breaks it. It caught it last time and broke the needle. How does this affect the thread and what can I do to fix it?
  • Sewing Machines Master
  • 7,365 Answers
Since the machine is a babylock I suggest having the machine
serviced to see if the machine has a timing problem or some part
is out of aligment.
Posted on Nov 07, 2012
3 Suggested Answers
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
  • 20 Answers
SOURCE: I have model 1477 and the spool thread does not
It sounds like a timing problem - the shuttle timing and possibly the needle timing needs setting. unfortunately this is a job for a mechanic.
Posted on Oct 13, 2009
Why does my machine break the thread a lot? A juki cp 130
tension too tight or incorrect threading, or bad thread.
Mar 13, 2017 | Juki Sewing Machines
On the lower loop blue keeps breaking
Looper thread breakage occurs frequently when the thread path is incorrect or threaded out of order. Most machine must thread the upper looper first, then the lower looper. The lower looper thread ends "draped over" the upper looper in the last step before being pulled toward the back of the machine and under the presser foot.
Another common cause is tension that is too tight.
VERIFY the thread path is correct for every thread!!!! Missing a thread guide or looping around a guide will throw your machine for a "loop."
Another hint, when threading, ALWAYS RAISE the presser foot throughout the process and be sure to give each thread an "extra little tug" when going through the tension to make sure it is seated completely. Sometimes, the thread will even "pop" when it seats. When a thread break, checks that the thread has not "jumped" out of a thread guide or the tension disk.
If the thread breaks, it is usually less frustrating (in the long run) if you remove ALL the thread and start over from the beginning. Trying to snake a broken thread out of order through the sequence is frequently 99% UNsuccessful!!! It takes a lot of familiarity with your machine to be successful threading out of order, but there is still a lot of room for failure!!!
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH
Make It Handmade How to Thread Your Serger Out of Order
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
Nov 17, 2016 | Sewing Machines
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
Thread tension on a Baby Lock BL90
I suggest changing both needles
and rethreading the machine
use a can of air that is used for computer keyboards on the inside
here's a link for parts to the machine and also has a manual
the manual should have information about the thread tension
http://www.sewingpartsonline.com/babylock-BL90-serger-machine-parts.aspx
Oct 29, 2012 | Baby Lock Sewing Machines
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Sewing Machines
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Jun 12, 2009 | Baby Lock Eclipse Serger
Bottom thread is looping.
If the thread is looping on the bottom, then your problem is on the top. Pull the thread out of the needle and and put the presser foot down. If the thread pulls thru easily, then you need to rethread your machine making sure the thread is thru the top tension wheel correctly.
Rule of thumb::
Loops on the bottom, Problem on the top
Loops on the top, problem on the bottom.
Apr 26, 2009 | Brother SE-270D Computerized Sewing...
BabyLock Proline upper looper thread keeps breaking
I ended up switching the spools of thread around. Apparently, even though I had purchased good quality threads, one of the spools was wound in a way that made the thread loop and twist around. So I put the offending spool of thread through one of the needles and put the needle thread on the upper looper. That seems to be working. By the way, BabyLoc was very unhelpful dealing with this problem.  Thank you!
Aug 26, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
71 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
