Question about Sanyo Xacti VCP-HD2 Camcorder
Sanyo HD2 is now very slow to start-up & switching between modes
During in-camera editing I switched off the camera -urgently... I had to move from where I was in public, urgently and so turned off the camera when it had not yet finished processing a lengthy video edit task.
Ever since that event, the camera has been slow to start-up, and a bit slower responding to switching from record and view and vice versa etc.
I wonder what I could do to make it speedier like it was before that day; any suggestions as to how to restore the camera?
Bye the way; all the photo data in the sdhc card within the camera at the time became unreadable so I deleted those photos, afterwards the sdhc card worked fine ever since.
Dear FixYa,
Thank you for your email asking whether I had received a solution to the problem I posted yesterday on your company's site.
I have not had any response to the problem I posted and will think about your offer to solve the problem for the fee you mentioned in your message.
I have had trouble finding your email address as the return address you left says 'do not reply', nevertheless I feel you may get this messasge by some means, perhaps someone in your company will pass it on.
Thanks again for your mild interest.
Yours sincerely,
text me with a solution.
+07879023247
Posted on Jan 06, 2009
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
Need instruction manual for sanyo xacti vcp-hd2 camcorder
Assuming you mean the VPC-HD2, you can download the manual from the manufacturer's web site at
http://us.sanyo.com/dynamic/product/Downloads/VPC-HD2_OM_English-6327393.pdf
Mar 18, 2010 | Sanyo Xacti VCP-HD2 Camcorder
Sanyo Xacti HD2 Flip Flash Not flashing
Hmm...I can't find a software control either. When the flash is down there is a cross through the lightening mark in the upper left portion of the screen, and when I press the flash button and raise the flash the same lightening mark in the upper left has no cross through it. Do you have the same mark? Does the flash button have no effect upon the mark?
Dec 18, 2008 | Sanyo Xacti VCP-HD2 Camcorder
USB device unknown
Make sure you are connecting directly to the computer's USB port, not through a hub. Try disconnecting other USB devices before plugging in the camera. Check the manufacturer's website for updaded drivers: if all else fails, a reinstall of the camera's drivers may be in order.
Mar 01, 2008 | Sanyo Xacti VCP-HD2 Camcorder
I need an "activation code" from Corel to complete the installation
Perhaps your camera only comes with a trial or limited edition of the software. Try proceeding without the activation code and/or read through the camera's documentation very carefully.
Feb 28, 2008 | Sanyo Xacti VCP-HD2 Camcorder
How do I fade in and out with the xacti? Regards, Cargman
on Xacti HD2 "menu" button doesn't respond in Recording mode... any suggestions?
Jan 12, 2008 | Sanyo Xacti VCP-HD2 Camcorder
Sanyo XACTI HD1 Camera-No Pictures / Videos captured.
I have intermittent problems of this type too. Occasionally I get a blank screen in the display mode.
Does the red light on the back of your camera flash while the screen is dark? Mine does.
It is beginning to bug me a lot. It may be because I got my camera wet in the past (and hence I have broken my camera), but I doubt that would result in a partial failure.
I think that the Xacti HD1/HD2 has issues a bit like a blue screen of death on an old Windows computer when faced with storage problems.
I.e. it works but crashes sometimes when it cannot store to its storage medium.
These things work for me
1) Turning the power on and off via the button underneath the screen.
2) Removing and re-inserting the SD card.
3) Turning the power on and off by removing the battery.
4) Using a different (and faster?) SD card.
I am still using my HD2, but I am finding that I must attempt solutions 1-3 about once a day.
It could be because the card I have been using recently is not fast enough. The HD2 accepts both SD and SDHC cards. My SDHC card (which is newer) seems to result in fewer problems, either because the SDHC format is more suited to the Xacti HD2 or becaues the SDHC card I have is faster that then SD card I have. I suspect problems with the speed of the card. I am using cheap SD cards.
Dec 07, 2007 | Sanyo Xacti HD1 Memory Card Camcorder
Device driver missing for Sanyo Xacti HD2 camcorder
i think your download video is compatible with the sanyo...you find a software with compatible......
http://www.altavista.com/web/results?itag=ody&q=Sanyo+Xacti+HD2+&kgs=1&kls=0
Dec 04, 2007 | Sony VAIO FRV37 Notebook
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sanyo Xacti VCP-HD2 Camcorder Logo
62 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
