Question about Viper Vehicle Parts & Accessories
Astrostart problem - RSS-2524
I installed the Astrostart RSS-2524 in my girlfriends 2005 mazda 3 with a manual transmission and it is almost working perfectly. I can do the required sequence in the car and take out the key and the car turns off after I close the door. The problem is when I try to remotely restart the car all the dash lights come on and everything just before it is about to crank but then it does not crank. The starter module flashes 4 times which in the manual indicates no RPM detected but that doesn't help because the only reason it doesn't detect RPM is because it is not trying to crank. Any help would be appreciated. Thanks Jon
ginko
  • 19396 Answers
SOURCE: 4 Faults detected on engine diagnostics check
Try first unplugging battery cable for ten minutuse, to reset ECM, and do a scan again, there are too many unrelated error codes at the same time
Posted on Oct 06, 2008
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
  • 34 Answers
SOURCE: Python 1400XP remote start system
yes you are correct the learn procedure is done by a dei 555L or a 555G bypass module.your car should have one or the other installed on it. simply unplug it,it will be a three wire plug. then plug it back in and then by turning the ignition on and off it will relearn the code.
Posted on Jan 09, 2009
ltfrc
  • 227 Answers
SOURCE: how do auto remote car starters work?
Usually the car start system has a "Valet" switch hidden somewhere under the dash or in the glove box. This is used to disarm the system for when the vehicle is serviced. You will have to locate and turn the switch on, some units have a small push button. In either case it is a good dea to locate it for future use.
Posted on Feb 08, 2009
SOURCE: 93 Bonneville,security light flashing,will not
i have been having problems with my 2001 pontiac grand am se 2.4 it has been jerking n skipping i put it on a comp at advanced auto parts i got this reading map\boro\circut high output and torque converter circut stuck on i need to know what the problems r and how to fix them i think the first one is a map sensor but i dont know about the torque converter circut can someobne help me i am gonna try n save some money and fix it myself if i can find out what these r and how to go about fixingt them
Posted on Feb 16, 2009
I have an Astrostart hst5224, It will star then immediately shut off. My jeep is A manual transmission
[PDF]MODEL RSS-5225 - DirectedDealers.com
www.directeddealers.com/manuals/OG/Astrostart/RSS-5225_OG-Eng.pdf
Immediately report any malfunction to the AstroStart dealer that performed the ... Always turn off the main switch when not using the remote starter for .... The startmodule will inform you of the status of door locks, the alarm and of the engine. .... If the trunk is opened for more than 5 minutes, the system switches to the.
How do you reprogram an AstroStart remote HST5224
www.answers.com > Wiki Answers > Categories > Cars & Vehicles
In order to reprogram an AstroStart HST5224 remote, you must putthe key in the ignition ... lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, .... C. Turn the ignition to ON (Do NOT Start) then back to OFF. ... B.Immediately after letting go of the lock and unlock buttons, press the lock button by ..
Nov 24, 2015 | 2007 Jeep Wrangler Unlimited Rubicon 2...
What model year transmission is compatible with a 2005 Mazda 3 sport
From Wikipedia.. "The Mazda3 or Mazda 3 (known as the Mazda Axela in Japan) is a compact car manufactured in Japan by the Mazda Motor Corporation. It was introduced in 2003 as a 2004 model, replacing the Familia/323/Proteg?. A performance-oriented version of the Mazda3 is marketed as the Mazdaspeed3 in North America, Mazdaspeed Axela in Japan and the Mazda3 MPS in Europe.
A second generation Mazda3 for the 2010 model year was unveiled in late 2008, with the sedan premiering at the Los Angeles Auto Show and the hatchback at the Bologna Auto Show. For the 2012 model year, Mazda began offering the Mazda3 with their newly developed SkyActiv technology, including a more rigid body, a new direct injection engine, and a new 6-speed transmission.[6]
The current third generation was introduced in mid-2013 as a 2014 model." My guess is the transmission from 2004 to 2009 mike be cross compatible. I would go to Autozone and ask or call the parts department at department at a local Madza dealer.
Apr 04, 2015 | 2005 Mazda 3
Astrostart troubleshooting
try in boot / trunk compartment, or behind the kick panels in the front foot wells and up under the dash board
Dec 24, 2013 | Vehicle Parts & Accessories
Can you take out a 2005 mazda 3 engine without taking out the transmission
If you are talking about getting the engine out of the car and leaving the transmission there, then no, not reall because of mounting promblem. You might be able to do if you have a shop with the a carlift. If you are talking about the engine and transmission as a whole and already out of the engine compartment, then YES you can dissemble the transmission from the engine.
Jan 23, 2011 | 2005 Mazda 3
Wher do I get a mazda 3 sport 2005 owners manual from?
Here you go...
http://www.devicemanuals.com/guide/Automobile/Mazda/2005-Mazda-3-owner's-manual-==TVRFd05ERXk=.html
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
Jul 31, 2009 | 2005 Mazda 3
Transmission Axles 2005 Mazda 3
mcdevito75, I have heard of 2 different type axles being used on Mazdas, the important thing though is the fluid leak. Have your local repair shop take a look and fix this leak.
Mar 28, 2009 | 2005 Mazda 3
Vehicle Parts & Accessories Logo
1,219 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
