Question about Sony VAIO VGN-CS310J/W PC Notebook
My laptop wont charge i think it has a broken internal power supply
  • Sony Master
  • 7,627 Answers
Bad cord/charger, bad battery? What give you the idea that " i think it has a broken internal power supply" Your saying your laptop will not charge the battery? Does the laptop work? If so the power supply is OK.
Posted on Nov 07, 2012
Battery wont charge
Is it a different charger? If it isn't try plugging it into a car or at home on the computer or the wall. If that doesn't work maybe getting it checked out will help.
Jan 07, 2014 | Amazon Kindle Fire HD
My computer wont charge. i think the internal power supply of the pc is broken.
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Nov 06, 2012 | Sony VAIO CS Series Notebook PC...
Ibm think pad does not charge
Hi There,
There are two things that may be wrong:
1 - check your power supply with a multimeter to ensure that it is putting out the proper voltage constantly. AC power supplies generally have a three year life span, shorter with laptops because they get pulled, shoved, twisted, etc.
2 - check that the power input pin on your laptop is in good condition. The board may be broken and you may need to find a new laptop.
Jun 07, 2012 | Dell Latitude D800 Notebook
Laptop wont even boot up
Do you have it on a power strip? if so try resitting it,if the battery is at full charge then you have an internal problem in the laptop itself.Bad power board,etc.Hope this helps.
Jul 25, 2010 | Acer Aspire One PC Notebook
HP laptop zv6000 won't charge battery
Get the Internal Power Unit checked as i can see its not been able to communicate each other.
May 03, 2010 | HP Hewlett Packard Pavilion DV9500T 17"...
Computer wont boot up
Take the battery out and try to boot the computer up with the external power supply.. If this works the the battery is shorted. If it doesn't then you will need to try another power supply, if that doesn't work then something internal has shorted in laptop
Feb 24, 2010 | Acer Aspire One PC Notebook
No power
HI,
you haven't mentioned clearly is the laptop in on state or are the batteries able to give power to laptop to start
try this solution if you have checked that the Ac Adapter is finr
take out the battery from the laptop and then plugin the AC adapter and then try to start your laptop
if your laptop starts without the battery by getting power through the Ac adapter, most likely your battery is Bad, get it replaced, if it doesn't start then it can be power circuit on the motherboard or the connectors you should get it checked from a technician.
If you think my solution was helpfull please do rate me
May 14, 2009 | HP Computers & Internet
Power problem - led shows the ac plug is in - battery does not charge - can not run laptop on ac adapter - what is causing this problem
The connection to the power supply inside the Pc is or has gone,
because your using the connection 1000 times a year, it faulters, and fails.
$150/$200 to get repaired.
Strip out the laptop solder connection back up,
rebuild, very common problem.
Regards
Richard.
Apr 18, 2009 | Toshiba Satellite A135-S4527 Notebook
Compaq nx500 battery wont charge
I could be that your battery ran out of juice. 6 cell batts can only charge upto 1000 charges then they die. Or it could be your internal laptop power supply.
good luck
Apr 17, 2009 | Compaq Computers & Internet
Sony VAIO VGN-CS310J/W PC Notebook Logo
59 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
