Question about Sony VAIO CS Series Notebook PC VGN-CS290JEQ
My computer wont charge. i think the internal power supply of the pc is broken.
  • Sony Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Nov 07, 2012
Why wont power on toshiba bdx5500 stay on ?
Condition of battery? Or power supply may not be supplying power to charge the battery.
Mar 26, 2015 | Toshiba Computers & Internet
Battery wont charge
Is it a different charger? If it isn't try plugging it into a car or at home on the computer or the wall. If that doesn't work maybe getting it checked out will help.
Jan 07, 2014 | Amazon Kindle Fire HD
My laptop wont charge i think it has a broken internal power supply
Bad cord/charger, bad battery? What give you the idea that " i think it has a broken internal power supply" Your saying your laptop will not charge the battery? Does the laptop work? If so the power supply is OK.
Nov 06, 2012 | Sony VAIO VGN-CS310J/W PC Notebook
Can you charge the 1440 using a usb to the computer?
For the software version: In the menu go to "Product Information" you will find it there.
If your GPS receiver has power pin port and a USB port the internal battery cannot be charged using your computer. You must use the supplied vehicle power adapter to charge the receiver's internal battery.
If your GPS receiver only contains a USB port it can be charged by your computer however we recommend using the supplied Vehicle Power Adapter.
Charging the internal battery using your computer may take up to 12 hours. Charging the internal battery using he supplied Pehicle power Adapter takes 4 - 6 hours. The receiver can be powered on or off while charging.
Most other answers can be found below.......
http://magellangps.helpserve.com/index.php?_m=knowledgebase&_a=view&parentcategoryid=68&pcid=6
Feb 17, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Computer wont boot up
Take the battery out and try to boot the computer up with the external power supply.. If this works the the battery is shorted. If it doesn't then you will need to try another power supply, if that doesn't work then something internal has shorted in laptop
Feb 24, 2010 | Acer Aspire One PC Notebook
The power light on my dell dimension 2400 is orange (it is not blinking). The loading light next to it is green. the computer is on but it will not do anything.It wont show the dell logo or anything. What...
You May hev one of two problems, either you towers power suply is broken, or on of the system fans are not working.
Check the power supply fan on boot. If its working check the CPU fan
Regards
Feb 21, 2010 | Dell Dimension 2400 PC Desktop
Power problem - led shows the ac plug is in - battery does not charge - can not run laptop on ac adapter - what is causing this problem
The connection to the power supply inside the Pc is or has gone,
because your using the connection 1000 times a year, it faulters, and fails.
$150/$200 to get repaired.
Strip out the laptop solder connection back up,
rebuild, very common problem.
Regards
Richard.
Apr 18, 2009 | Toshiba Satellite A135-S4527 Notebook
Packard Bell w3910 d - Doesn't charge or get power from AC adaptor.
Sorry to say, power supply for laptop is harder to repair then PC (but repair able). You will need to get access to the board.
Maybe get a standalone battery charger ?
May 15, 2008 | Computers & Internet
DELL 600M AC POWER CORD
The internal power supply of your PC is broken, it needs to be serviced.
Feb 13, 2008 | Dell InspironTM 600m Notebook
Sony VAIO CS Series Notebook PC VGN-CS290JEQ Logo
51 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
