Question about Seiko LD6370 Dictionary
Display screen problem for seiko LD6370
Some of the characters are missing or not showing up. I am missing 2 bars of pixels at the end of my organizer. The display is hard to read, especially the numbers in the calculator section, because they appear broken up. How do I fix this problem and what caused it?
5 Suggested Answers
SOURCE: Random characters lines and pixels
I've had a similar problem in the past with my TI-86. It still happens sometimes when I don't use it for a while. To fix it, all I did was set the screen to its darkest setting and left it on for 10 minutes (keep it from turning itself off, by pushing buttons every few minutes.) It works great, and the calculator is fine unless you leave it unused for a month or so. A similar solution may work for you.
Posted on Jul 10, 2007
SOURCE: The Seiko s149 will not display anything on the screen.
We had to change the internal battery on ours today. There are 4 screws on the back of the case and 3 inside the AA battery compartment. Careful pulling the front and back apart as there are some wires that attach between the two. Two of the three screws need to be removed to get the CR2430 battery out to replace it. We now have the watch screen...just need to remember how to operate it...need a new users manual.
Posted on Sep 26, 2009
  • 3 Answers
SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Posted on Dec 01, 2009
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
oneplusgh
  • 100 Answers
SOURCE: Some menus have a pixelated appearance, similar to
Hi fakereal tru,
There is nothing wrong with your calculator. Those are just options that are not open to you yet. Texas Instruments will continuously keep adding new feature with every upgraded OS that they come out with. When you install a new OS you will see some new features where there wasn't ones before.
Posted on Jan 06, 2011
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Sony vaio laptop screen shows vertical lines upon booting then proceeds to windows loading with semi transparent vertical bars on background. Upon logging in, screen displays everything in a large scale...
the screen inverter is on its way out simple to replace unscrew the rim on the outside of the screen pull it off gently at the bottom there is a stip with wire going into it at each end disconnect it remove it do the reverse to put it in i suggest ebay for spares
Feb 11, 2012 | Sony Computers & Internet
When I turn camera on, the screen is full of pixels; also the same when viewing images
2 things could be fault here. If you are able to goto a menu setting and still have pixel issue, then the video interface for the display is damaged. Not usually worth repairing. If the menu shows clear, then try to take a picture, and use a computer to view the picture (USB cable, or remove the memory card). If the picture shows pixels, then the image sensor is bad, and almost never worth repairing unless high end camera and under warranty.
Aug 21, 2011 | Canon Cameras
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
Explain this phrase and give the solution. cyberlink youcam does not support a screen resolution smaller than 1024*768
  1. The resolution is about how many pixels are used to display images on your screen. How you change the resolution depends on what version of windows you have but they're all pretty similar. Hold the mouse pointer over your desktop (i.e. any programs that are open minimised)
  2. Press the Right mouse button and a menu will appear.
  3. In windows VISTA click "personalise" (in earlier versions click properties)
  4. Click DISPLAY SETTINGS (in windows vista, DISPLAY in earlier versions)
  5. You'll see a bar with HIGH at one end and LOW at the other end. Beside the bar it will show the resolution. If you slide the marker on the bar up or down the resolution will change. Set it at the resolution you need and click APPLY.
  6. You'll get an option to keep the new setting. Click YES if everything is displayed ok. If not click NO.
Sep 07, 2010 | HP Pavilion dv9000z Notebook
How can i cancel a buy in ebay before ending auction ?
you can retract a bid if there is still more than 12 hours left in the listing before it ends. here's how:
1. log in to your account then click site map located on the upper right hand corner of the page.
2. then in the site map page, scroll down and on the left side click bid retraction. you will need the item number and for the reason, you can choose any. then hit retract bid.
Oct 31, 2009 | Seiko LD6370 Dictionary
The control panel display is blank on my lexmark x6570 printer
If the LCD on the operator panel constantly displays black bars/boxes or other unusual characters, take the following steps:
1. Disconnect the power supply from the printer.
2. Wait for about one minute, then reconnect the power supply and check the LCD display.
3. If black boxes/bars or unusual characters are still displaying constantly, move the power supply to a different power outlet.
4. If the black boxes/bars or unusual characters are still displaying, the scanner ribbon cable may need to be reseated. Do the following:
1. Lift the scanner flatbed. (Open the printer as if attempting to install cartridges.)
2. Look in the back right corner of the 6150/70 for an access cover.
3. Press firmly on the front right corner of the access cover to reseat the scanner ribbon cable that is located underneath the access panel.
Oct 01, 2009 | Lexmark X6570 InkJet Printer
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Amilo A1650G laptop display problem.
ur display memory is corrupted. normally it is a shared memory or a part of the main memory unless u r using the graphics card.
try take out the RAM, clean it and put it back and switch on.
if not helped this, try with a good RAM.
good luck
Please don't forget to rate or accept the solution
Jun 18, 2008 | Siemens Computers & Internet
Characters & menus display incorrectly
It is a display driver issue. You can buy a new one or get it repaired ($100).
Feb 10, 2008 | Texas Instruments TI-85 Calculator
Seiko LD6370 Dictionary Logo
60 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
