Question about Relic 0504648FA
How to set day on relic watch - Relic 0504648FA
SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
  • 1 push pin like you use on bulletin boards with a plastic head
  • 1 small hammer like a tack hammer
  • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
  • 1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Jan 09, 2008
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Posted on Feb 10, 2009
SOURCE: how to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
Posted on Mar 13, 2009
disap1
  • 98 Answers
SOURCE: How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
Posted on Jan 09, 2010
escapement
  • 2334 Answers
SOURCE: set the date on my new relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Posted on Mar 23, 2010
How to set the time and day and date on a relic zr15701
Pull the crown out once to set the date. Pull it out a second time to change the time. Of course move the crown up or down and see if it will change.
Dec 24, 2013 | Relic Degrade Pocket Watch
Need to know how to set the time on my watch
Mar 27, 2010 | Watches
Set the date on my new Relic watch
Mar 22, 2010 | Relic watch
Do as folloes:
Feb 09, 2009 | Relic 0504648FA
How to set the time on relic watches
Dec 27, 2008 | Relic Degrade Pocket Watch
Relic Watch is running slow
Try replacing the battery.. Did you use Paypal... if the battery doesn't fix it... Contact the seller... ask for a refund (UNLESS - it said "as is - no warranty") .. then Use Paypal's services to get your money back
Jun 25, 2017 | Watches
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Sep 03, 2008 | Watches
Resetting time on relic watches
Press and hold the Mode button - upper left. At first, it will display the stopwatch function. Keep holding until it goes to flashing alarm set mode. Once it starts flashing, release the button and then immediately press it again and release it (do not hold it the second time). Now you are in time set mode. You can change the time, starting with the seconds, by pressing Adjust - upper right. You can move to minutes, hours, day, and date by pressing Alarm - lower right. Pressing Mode again will exit the set function.
Jul 09, 2008 | Watches
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Relic watch 3 dial
Chances are they represent one of the following-
Month of the Year
Time of Day (military time)
Day of the Week
Day of the Month
It depends on what the dials have on them - usually there is some indicator (abbreviated months, numerical values, etc)
Feb 20, 2008 | Relic 0504648FA
Relic 0504648FA Logo
126 people viewed this question
Top Relic Watches Experts
Ansel Alberto
Ansel Alberto
Jim Parker
Jim Parker
Are you a Relic Watch Expert? Answer questions, earn points and help others
