Question about Nintendo Wii Console
Dead Wii Console
HI i have a wii console and it is dead,ie no picture and the controllers do not sync.I have tried resetting it but to no avail.Can you tell me what is wrong with it and how to fix it. Many Thanks Bogdan
  • ekiMike May 11, 2010
    Did this happened after trying to change the firmware?
Motherboard problem
Posted on Jan 05, 2009
My remotes were synced to another wii how do I re-sync them?
Step by step instructions on how to sync the Wii Remote or Wii Remote Plus to the Wii console using Standard Mode.
Note:
Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
What to Do:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. If you are using a Wii mini, the sync button is located left hand side next to the battery compartment. The sync button is a darker shade of red than the console.
  3. Remove the battery cover on the back of the Wii Remote to be synced.
    • Some models of the Wii Remote include a hole in the battery cover and a tool on the wrist strap to push the SYNC Button with. With this model, the battery cover does not need to be removed to access the SYNC button.
  4. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the Wii console.
  5. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  6. This sync procedure must be followed for each additional Wii Remote added to the system.
May 19, 2014 | Nintendo Wii Console
I can't seem to sync my wii controller. All 4 lites are blinking and will not stop. I changed the batteries and tried to re-sync the controller w/no luck. It was just working a few minutes ago.
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
if nothing else works call 1-800-255-3700
Jul 12, 2011 | Nintendo Wii Remote Controller
The wii remotes won't turn on even when you try to sync them
make sure flat side of batteries are on springs, make sure batteries are not dead(or chargeable and dead), to sync follow these steps
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
Jan 15, 2011 | Video Game Consoles & Games
Console does not respond to all remote actions, ie no cursor on screen,only the minus , home , and plus buttons work i have tried several remotes and changed the sensor bar.
I would try to re-sync the controller to the console.
1. Power on Wii
2. remove battery cover from wii remote; press sync button on remote, will cause LED's on remote to blink.
3. Press the sync button on the console (it is located in the memory card holder on the front of the console)
4. The remote is connected once the LED stops blinking. The lit LED indicated what player # the connected controller refers to.
If you are still having trouble then delete the configuration info first and then re-sync the controller to the Wii.
Do this by holding the SYNC button on the console for 15 seconds after turning the unit on (once you see the health and safety screen). After you do this you will need to re-sync the controller individually.
It also warns of bright light sources like sunlight near the sensor bar, highly reflective surfaces (mirros, etc.) behind the sensor bar, sources of infrared radiation (portable heaters or fireplaces) or radio interference from cordless phones, cell phones, etc. as possible causes of interference. See pages 22, 32, 34 of your Wii owner's manual for full information, or call 1-800-255-3700 if you are still having difficulty.
Dec 31, 2010 | Nintendo Wii Console
My Wii Remotes no longer sync up with the console. How do I remedy this problem?
I'm sure you have tried most of these steps but I'm going to list them any way. So we have a complete picture of the trouble shooting process.
1. Sync system first (by pressing the sync button located next to the SD memory slot)
2. Right after you hit the sync button on the system, hold down the 1 abd 2 buttons on the remote (or press the sync button located under the battery cover).
Try replacing the battery's and or rechargeable battery for the controller. Repeat the sync process above.
Try another controller with your wii or try your controller with a different wii. Repeat sync process above.
If another controller works with your system than that would indicate that there is an issues with your xbox controller.
If your controller works with another wii and no other controllers work with your wii than there is a issue with your console.
If your wii is still under warranty I suggest contacting Nintendo directly.
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 26, 2010 | Nintendo Wii Console
The ON button on the Wii remote doesn't respond. Tried new batteries but still no response. No blue lights, nothing! Tried patting it, reset button, all instructions as listed in troubleshooting. Had since...
Try reseting the wii console. This is done by removing the battery from the botton of the console. There is a small battery bay held in by 1 screw. Leave it out for a day and after you install it make sure you press the conect button on the wii. (located under SD card reader door). And the connect button on the controller (located in battery compartment on back of controller). Good Luck.
Nov 24, 2009 | Nintendo Wii Console
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
Wii Controllers commplety shut down
Try changing batteries or pressing the sync button on both your Wii and Wii remote.
Jul 12, 2009 | Nintendo Wii Remote Controller
The controller shows that the batteries are dead on the screen. We replaced them with several sets of new batteries and the battery indicator light is still read and showing the batteries are dead.
So you having problem with battery issue on Wii?
Try this:
1. Re-SYNC your WiiMote between wii.
2. Open the battery case of WiiMote, Click red button.
3.Open the SD card case of Wii console, Click the red button.
4. It will re-SYNC together again.
Hope this help! Any questions? feel free to PM me =]
Jul 07, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
96 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Troy Gorman
Troy Gorman
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
