Question about GPS
I have a garmin nuvi 265wt plug it in to recharge it comes on for about four seconds and switches off then the same again and again
    Top Expert:
  • 14,553 Answers
If using the lighter plug for this open it and see if a fuse is inside; a bad battery is possible but not real likely---you can also try for help with customer service for this brand.
Posted on Nov 07, 2012
SOURCE: garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Posted on Dec 06, 2009
hemantraj
  • 638 Answers
it can be batter problem or sometimes the battery is okay but the contacts of the batter on the board chip r loosened.just get it serviced n dry soldered n it will be back to work.even i had a same problem with my device few days back i doubted battery first n changed a battery but it didnt help so i was sure about the chip n just got it repaired n its working perfectly fine now.hope itworks for u too.
feel free 4 further assistance n keep sending more question n comments or doubts that arise in ur mind regarding this to me.rate the solution as fixya if it helps u understand n solve ur problem
Posted on Jun 18, 2008
  • 32 Answers
SOURCE: How do I register my new Garmin nuvi 265WT
first of all you will need a computer with an internet connection. then go to www.garmin.com
click on registration. your unit must be plugged into yor computer. you will find your unit serial number when you remove your battery. follow the instructions and you will be able to register your unit.
Posted on Sep 06, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi Doesn't turn on
Try resetting the unit. The procedure can be found here:
http://www.sharc.net/discus/messages/6/313.html?1268661443
- Jim
Posted on Mar 19, 2010
pabloloco
  • 2335 Answers
SOURCE: Downloaded and installed Bluetooth firmware update - Won't Pair
I recommend rerunning the webupdate software available below, which was updated March 30, 2010. Run through the update steps again.
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
After successful webupdating, a hard reset is often helpful at this time, too.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Posted on Apr 19, 2010
My garmin nuvi won't turn on? i've tried to plug it into charger but nothing happens
I can help you reset and fix your Garmin Nuvi 265WT.
Erratic behavior is an indication that the firmware / system software inside your GPS has been corrupted.
It is not necessary for your computer to be able to 'see' your Nuvi in order for the firmware update to work. When it is successfully updated, the Nuvi will communicate properly to the computer, and your pc will 'see' it, and you can load your maps.
There are three steps to take to get your Nuvi 265WT running like new:
I hope that helps.
Nuvi 265WT Change Home Phone Number
Nuvi 265WT Delete Phone Numbers
Apr 10, 2010 | Garmin nuvi 265 Car GPS Receiver
Tip
Garmin Nuvi 265WT Change Home Phone Number
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to edit the phone number entry on your Garmin Nuvi 265WT for the Call Home option?
To edit your phone number touch:
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
____________________________________________
Erase Nuvi 265WT Phone Numbers here.
Backup your Nuvi 265WT Favorites here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 23, 2010 | Garmin n?vi 265WT Car GPS Receiver
Tip
Download Nuvi 265WT Manual Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W,...
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 265WT GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
Backup & Restore Nuvi 265WT Favorites here.
on Apr 19, 2010 | Garmin n?vi 265WT Car GPS Receiver
Garmin will not come on
Not starting, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
I hope that helps.
Feb 21, 2010 | Garmin nuvi 265WT Car GPS Receiver
Tip
Garmin Nuvi 265WT Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
Would you like to back up a copy of your Garmin Nuvi 265WT Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
Tip
Garmin Nuvi 265WT Webupdate Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Does your Garmin Nuvi 265WT GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
How delete the home phone number
I can help you edit your Nuvi 265 home phone number.
  1. Where To?
  2. Favorites
  3. Home
  4. Edit
I hope that helps.
Dec 24, 2009 | Garmin nuvi 265 Car GPS Receiver
After a map update my garmin 265 wont talk
I recommend reupdating your Nuvi 265WT with the newest firmware, and then performing the Hard Reset a second time afterwards to ensure the 'voice' functions come back on.
I hope that helps.
Oct 01, 2009 | Garmin n?vi 265WT Car GPS Receiver
I hope that helps.
Sep 09, 2009 | Garmin nuvi 265 Car GPS Receiver
GPS Logo
67 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
