Digital input self test feature check moving across black screen - how do I get it off?
  • 1 more comment
  • joecoolvette
    joecoolvette Nov 07, 2012
    By getting the computer to work. Computer isn't working to send a video signal to the monitor. No Signal. Monitor goes into self-test mode until computer works. Is it a Dell computer? What is the model number? (Back of computer next to Windows product key, or up on side of computer tower) Post back in a Comment.
  • Lisa Maffia
    Lisa Maffia Jan 29, 2015
    I have same problem
  • Lisa Maffia
    Dccy
  • 2,878 Answers
No video input. Connect or select correct input.
Posted on Nov 07, 2012
2 Suggested Answers
rommelalilin
  • 2178 Answers
SOURCE: Dell,1: Auto detect (digital input)
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/index.htm
Posted on Nov 04, 2010
I have a lexmark x8350 all in one.there is a color missing error
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Next, lets try to print the self test.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." This is essential. Then plug the printer back in and follow these steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously.) Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail.
your's tech expert
Jeeth
May 21, 2010 | Lexmark X8350 All-In-One InkJet Printer
X8350 All-In-One InkJet Printer: printer does not recognize color cartridge...
software. Try to print the self test. If failed try another cartridge if you dont get any
error then the cartridge might be defective.
steps:
black cartridge installed.) If you find that either cartridge causes the self-test to fail,
please let me know.
your's tech expert
Jeeth
May 18, 2010 | Lexmark X8350 All-In-One InkJet Printer
Getting printer stall code on screen...
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Press and hold the "Plus" (+) button. While holding it down, press the "Scan" button. Once the screen changes, release both buttons. The screen will display the firmware version until the buttons are released. Then it will display 0: Button test.
2. Press the "Plus" (+) button once. The screen will display "Single Test Page."
3. Press the "Menu" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed.  If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 03, 2009 | Lexmark X5250 All-In-One InkJet Printer
Lexmark x5495 all in one.paper does not come out when printing
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridge. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
May 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Computers & Internet Logo
969 people viewed this question
David Payne
David Payne
