Question about Dryers
Ivar Room Thermostats - Dryers
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 07, 2012
Meaning of the first name IVAR?
Ivar comes from ancient Norse/Scandinavian and means "The Archer" or "Bow Warrior." Not sure why this question was in computer support, but love the meaning of the name.
Jun 08, 2017 | The Computers & Internet
How long does it take the room temp to get to a/c set temp
That will depend on the temperature difference between the room now and where you want it to be. Also the size of air conditioner, how big the room is. Too many variable to give an exact answer.
Jul 12, 2015 | Heating & Cooling
Room Tempurature on theomastat is not showing correct room tempurature
Sometimes thermostats Just go bad or are miscalibrated. Sometimes when it is on an exterior wall and it wont show the right room temp due to the wall being cold. Move to interior wall or replace.
Feb 15, 2015 | Heating & Cooling
It is increasing temp 2 hours before scheduled
Most programmable thermostats are "smart stats" which use a programmed algorithm base on a preprogrammed P (proportional) I (Integral) D (derivative) Loop. To make a long story short, the programmed temperature will make the room that temperature by the programmed time. This is based on how long it has taken it in the past to bring the room up or down to temperature. So if your setpoint is 70, and your set time is 7 AM, then the furnace or AC will bring the room to that temperature by the set time...not start at the set time.
Dec 04, 2013 | Heating & Cooling
Electric dryer. We replaced the heating element. Now a soon as you turn it on, the back inside of the drum glows red hot. Could it be the themostat?
HI. The thermostats in this particular case will be the focal point for your troubleshooting. I would recommend to test all that are included in the unit, especially, the high limit thermostat. I believe this will be the culprit. Be sure that the unit is well ventilated, also. clean out the entire ventilating assembly, if needed.
Thermostat testing procedure:
To test the thermostats or fuse, set your multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
NOTE_ If all temperature monitoring devices test out ok; Replace the main control device.
Dec 06, 2010 | Dryers
Turning room thermostat down, doesnt cool room
You have a safety switch switch on your system that is opening and locking your system out, not allowing it to come on. This is telling you that there's a problem with the system and it needs to be checked out.
Mar 19, 2010 | Honeywell Programmable Thermostat Heater
The dryer is working, however it is not drying. THe air is room temperature. I beleive I need to replace the fuse. How do I know which to replace?
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse. To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Oct 10, 2009 | Kenmore 73952 Gas Dryer
Drum turns, poweris present, does not heat
HI. To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Sep 29, 2009 | Dryers
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Thermostat displays 79 deg but really 68 in room
If the thermostat does not have a reset, replace it.
Nov 05, 2008 | Honeywell Programmable Thermostat Heater
Dryers Logo
88 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
