Question about Saeco Talea Giro Espresso Machine
Talea giro plus / Descaling with vinegar
Descaling : Is it possible to use a vinegar solution for descaling instead of the expensive Saeco decalcifier ? If not, why ? If yes, what would be the ratio (in parts) vinegar / water of the solution ?
    Novelist:
  • 133 Answers
There are a couple of things I am thinking for this:
If the espresso machine is not spraying the hot steam like it should it says in the manual to take apart the steam apparatus and clean with hot water then to run hot water through the device after each use to clean.
Furthermore, have you seen those CLR commercials? I am sure white vinegar would be fine to put through the machine. As far as the ratio is concerned use a low concentrate to start out like 1 to 3 then increase until desired results occur.
I hope this helps!
Posted on Nov 06, 2012
  • 1 more comment
  • Isabelle Marchand Nov 08, 2012
    Thanks for the ratio. I have no problem with the hot steam, though. Anyway, in the meantime, since this machine will refuse to work before you have proceeded with the decalcifying cycle, I did it with plain water. It fooled the machine for this time ! Since this machine answers to office use (10 coffee lovers), I know that I should do it with the vinegar or Saeco specific solution at some point, sooner than later. Also, I read that vinegar is not recommended because it brakes the calcium it very small parts that can hurt the pipes of the machine, when the Saeco solution melts it. How much of that should I believe ? And I wonder, if I want to extend the three-month period between the decalcification processes, how long should it be to play safe with the machine maintenance ?
  • Allister Feb 02, 2013
    a common
    a common and gentle decalcifying agent is citric acid.
  • 4 Answers
I asked my chemical engineer father this ... thinking that Saeco just wanted to sell me their pre-made descale solution for $10/bottle. However, my chem eng dad said the manual says not to use vinegar because the machine uses certain plastic or metal parts that will deteriorate with vinegar. The ready made solutions you can buy from Saeco are made mostly of citric acid and don't affect plastics/metals. This is a naturally occurring substance and is not toxic like some of the other commercial cleaners (CLR etc.)
Posted on Nov 11, 2014
  • 74 Answers
SOURCE: Saeco Odea Giro descaling problem
Ok first check if the machine is in greenlight state when you press and hold the water button, as it will not work when the red exclamation mark blinking.
also check if the button work at all flipping back and forth to hot water and steam.
I have never had this problem that it dident work.
But remember this, you dont have to do the descaling again as that has nothing to do with the reset.
You can even reset the descaling alarm with out having done the descaling.
If that for some reason wouldent work I would think its the CPU card is not working.
Posted on Jul 14, 2008
  • 81 Answers
SOURCE: talea giro plus. csan't exit descale cycle
Keep pressing the water button for 6 secs until the flashing light goes off.
Posted on Jan 24, 2010
EsWorld
  • 1618 Answers
SOURCE: I have a Saeco odea
You can do that using the hot water cycle.
Posted on Sep 02, 2010
rohntech
  • 422 Answers
SOURCE: My Saeco Talea Giro plus
Did you often use the espresso machine for family or for business, when you often use the machine and you used water that is not filtered, you can assure it need to descale often.
Read carefully the manual and follow instruction. Did you descale it in the right amount of solution, how long and its duration?
If still persist ( the descaling light continue flashing ) then it has a defect in sensor. Since your machine is new, its under warranty. Call the dealer where you brought that and a service technician will send.
I hope I give you answer and solution idea for your unit problem.
Posted on Mar 29, 2011
SOURCE: Saeco Talea Giro Plus, descaling
Try doing another rinse cycle until water tank empties. I had to do that a couple of times, then the red exclamation mark came on. Then I turned knob to off position, refilled water tank, pressed the descale button for 6 seconds, green light came back on and it did its priming.
Posted on Apr 20, 2011
Why, when descaling a saeco talea giro plus only steam comes out of the wand
Try holding the descaling button for 6-7 seconds (not 3 as the instructions say) until it stops flashing.
Jun 11, 2014 | Saeco Coffee Makers & Espresso Machines
How can I descaling my Saeco Odea Giro? What can I use to do it if in my country I don't find the descaling solution?
50/50 solution vinegar 50% filtered water and 50% vinegar. fill reservoir with this solution as if you were making a pot of coffee. Run 2 or 3 pots fresh filtered water thru unit to clear out vinegar taste.
Feb 20, 2013 | Saeco Odea Giro Espresso Maker -...
Our saeco talea giro descaling light is on and after a full descaling cycle it remains in the descaling mode. any ideas? thanks
To remove a descaling light you need to hold down the steam/water button for 6 seconds and the light should go off. The button is located on the right side of the coffee button.
If you are in need of the manual you can download it here
May 10, 2011 | Saeco Talea Giro Espresso Machine
My Saeco Talea Giro plus is not even one month old and the descaling light was on. We have descaled twice thinking we did something wrong and the descaling light will not go off. During descaling the...
Mar 29, 2011 | Saeco Talea Giro Espresso Machine
Saeco Talea Giro Plus, descaling following instructions step by step. In step 12 the descaling light did not turn off. The warning light came on as indicated. In step 15, pressing the descaling button...
Mar 26, 2011 | Saeco Talea Giro Espresso Machine
Talea giro plus. csan't exit descale cycle
Jan 16, 2010 | Saeco Talea Giro Espresso Machine
Saeco Talea Giro Espresso Machine Logo
436 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
