Question about Samsung Refrigerators
RF267ABRS door repair
Left door flap will only close manually
mastatech
  • 478 Answers
SOURCE: flap on refrigerator door will not close
You will need to replace the solenoid kit for door.Call us 704-819-6557 same day shipping
Posted on Mar 14, 2009
aasc
  • 1606 Answers
SOURCE: GE ice dispenser door hangs down
You should replace the dispensor solenoid and plunger due to rust . Very common problem with G.E.
Posted on Jul 11, 2009
aasc
  • 1606 Answers
SOURCE: ice dispenser door flap will not close.
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Posted on Sep 02, 2009
  • 112 Answers
SOURCE: shoot door (flap) for ice maker wont stay closed causing frost
the gear that pulls it closed is bad. some have small plungers instead of gears
Posted on Oct 29, 2009
  • 50 Answers
SOURCE: i have a kenmore elite side by side with icemaker
there is a solenoid in the door assbly. it may just be corroded but may require replacement.
Posted on Aug 01, 2010
Good day! The center flap (vertical hinged flap) no longer rotates back in when closing the left door. Result: the flap remains "out" when closing the door thus banging up against the right door.
Their is a factory issue on some models call the factory to see if your unit is a defective unit. Other wise the door flap has to be replaced. Not cheap..
Oct 30, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
The door flap on my KitchenAid French Door fridge isn't springing completely back into place, and it's catching on the other door.
Locate and adjust the spring responsible for getting that flap into proper place and all will be resolved.
Aug 30, 2015 | KitchenAid Refrigerators
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
Daikin Split AC :- Vertical airflow flap not closing properly
Something is broken at the joining of the door which is not allowing the door to close
Apr 24, 2014 | Heating & Cooling
Right door flap not hugging door when ioening left door with right door already open
The doors have to be adjusted. They may have moved out of their intended alignment over time
May 01, 2013 | Frigidaire FGHG2344MF Bottom Freezer...
Rf267abrs only 14 cubes of ice in 1 day
I would give it a few more days most icemakers will not cycle if the temp around the icemaker are above 15 degrees F.Leave the door closed.Open door for even one minute can take a while for freezer to cool off to temps around 10 or colder. Also if you do not have much in there it may be a problem as well it is harder for freezer to cool open space. If I can help with anything else please let me know.
Apr 08, 2010 | Samsung Refrigerators
Reg door will not close
There is a flap inside the printer that guides the paper as it travels thru the printer. The flap has to be in a completely up position before the door can be closed. Problem is if you put the flap in the up position and then try to close the door the flap falls back down and blocks the door. You need to push the flap up and close the door quickly before it has time to fall back down.
Apr 01, 2009 | Dell 3100cn Laser Printer
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Refrigerators Logo
93 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
