Question about Sony Playstation 3 (PS3) Console
NO output either HD or normal tvs (not on/off botton hold prob)
I already know about the holding the on/off button for 5 secs to change the output between HD and normal. i have tried this method before and it always work but now its just a black screen. I have tried it on both HD tv (using HDMI cable) and normal (using component) held the on/off button for 5 secs, it beeps then the screen flickers then...nothing.
tried inserting a disc in and i noticed theres a loading icon on the top right hand corner of screen...so that tells me that the input does work but then it goes black again, No main menu screen or anything
  • derocslickma Jan 07, 2009
    man i just thought it was some sort of system setting I accidentally press "disable" on. Your solution sounds by far most logical out of all i read on similar problems and definately will look in to, but before i go spend some BONES on a new HDD drive how sure are you that this is problem is related to corrupted system files.
    by the way...how do you reformat the corrupted drive on the PC if your solution is true.
  • 3 Answers
Hi, The fact that you are getting a load icon when you put a disc in makes me think you have corrupted system files. If you have a spare 2.5 SATA drive you could put it into the PS3 and let it auto-format it, see if that gets the menu back for you. If it does then your current drive probably needs to be reformatted on a PC and then re-inserted into your PS3.
You'll lose your save games (unlesss you can back the drive up on the PC).
Posted on Jan 05, 2009
  • omoorej Jan 07, 2009
    Hi, I don't know for sure that it is corrupted system files, but the fact that you are getting a load icon leads me to believe that the output is working, and the fact that it comes up when a disk is inserted would point to the BD drive working (or at least working enough to detect a disc).
    Before you buy a new HD you might want to try restoring system files from the recovery menu. You should be able to do this without loosing any save game files. Follow these instructions;
    The current version of the ps3 firmware has a “recovery console”.
    You access it by
    1. Start with having the system in standby (redlight is on)
    2. Hold the power button down; the system will turn on and turn off once again.
    3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
    4. You will be prompted to plug in your controller via USB and then hit the PS button
    You will now have a screen with these options
    1. Restart System: Restarts the PLAYSTATION®3 System.
    2. Restore Default Settings: Reset all system settings back to default.
    CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
    4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
    5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
    6. System Update: Update the PLAYSTATION®3 System
    IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
    I REPEAT CHOOSE RESTORE FILE SYSTEM
    After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
    Here is a video showing how to get to the recovery menu too;
    http://uk.youtube.com/watch?v=_2YnGGUOJk...
    If the Restore File System doesn't work you can try the Restore PS3 System option, but this will wipe al your saved data, so only use as a last resort.
    If none of these work then i would remove the HD and hook it up to a PC and format it. It doesn't matter what you format it with as the PS3 will reformat it to it's own specifications when you put it back in. This is pretty much the same option as Restore PS3 System from the recovery menu, but by formatting it first you should have ensured any corrupted sectors on the disk have been found and recovered or marked as bad so that they wont ne used in future.
    Sorry for the very long post, I just wanted to offer you some options before you spend any money on a disk.
I tried to change my password and i closed the page before it finished and when i tried to connect to the internet it wont work help
Perform a reset. Find the hidden reset button, usually close to power line, find a small hole with a little button behind it. Use a toopick or similar to hold down power button for at least 10 seconds. This should restore it to factory setting and default password. Google the model # and brand and "default password" if you don't already know it. If this does not work to reset it, then try this...
Hold down reset button for 30 seconds, still holding button pull the power out, keep holding button for 30 secs, STILL holding button - plug in power then release button after 10 secs.
Yes 30 secs each cycle is overkill, but allows to be sure.
Aug 11, 2013 | Computers & Internet
Cant get demo off on a samsung tv LE32C450E1W
Try doing the same thing, except instead of holding the menu button, hold the power button
Aug 29, 2012 | Samsung Televison & Video
DO YOU FIX PS3s... I have tryed everything i can think of incloding different cables HD & normal,different TVs HD & normal Also holding down the power button and waiting for the beeps.But nothing...
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
SAFE MODE
Have a look at this, it may help.
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
My samsung lcd 40inch tv keeps on changing "source" every few seconds , its driving me crazy.
hi,
the function board might have stuck on the source botton. try press n hold on the source botton and see if it is back to normal.
Mar 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Switching our ps3 from hd to normal
with only the PS3 and the TV connected, touch and hold the systems’ power button for more than 5 seconds to switch the system back on. The video output settings will automatically be reset to the standard resolution
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
I have hx 460 but no manual. It is in the locked status and I only have access to channel 16. How do I unlock.
Most of the time if your handheld is in a locked status, there will be a single button that needs to be held for usually about 3 to 5 seconds to unlock it. Some Standard radios have a botton with a Key symbol. If your's doesn't have a botton like this, try holding each botton for 3 to 5 secs (1 at a time).
Feb 20, 2009 | Standard Horizon HX460S 2-Way Radio
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
AV multi out
when the power is off press and hold the power button until you hear two beeps
May 14, 2008 | Sony Playstation 3 (PS3) Console
Nothing appearing on the screen
you need a scart box the one that you put the yellow red white plugs in to then you put it in the back of the TV than go to av on the TV remote that normally works on new and old TVs
Jan 03, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
115 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
