Question about Jura Capresso Impressa X90 Espresso Machine
Impressa 95 says empty tray but its empty
I have x95 it says rempty tray but nothing in tray?
  • 4 Answers
SOURCE: Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
  • 4 Answers
SOURCE: impressa z5 grounds empty will not reset even
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
SOURCE: I was going through the decalcifying process and
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
Posted on Oct 24, 2010
SOURCE: I have a Jura Capresso Impressa S9 and it keeps
Where the contacts attach to the drip tray on the inside is where I had some coffee ground "sludge". It was making a weak electrical connection between the two contacts. As soon as I took a fine scrubber sponge to get rid of the build up - the Empty Tray message went away when I put the tray back in.
Posted on Oct 23, 2011
Jura z7 error message empty coffee tray when tray s not full
Yo James,
I know nothing of your unit, but I've never let that stop me before??.
Sounds like a sensor is stuck in the "tray full" position and popping an error message based upon what "it" is detecting.
OK, how does the unit know from "full tray" (what ever that means). I'm a big believer in problems being created by dirt, crud and in your case, coffee grounds. Unless the sensor (switch?) itself has failed, I'll bet there is debris fouling the system.
Find the "full tray" (what ever that means ??) sensing mechanism and clean/replace it and I'll bet you will solve the problem.
All the best.
Dec 07, 2014 | Jura Impressa Z7 One-Touch Automatic...
Pc x95
If you are using windows, then go to the Printers dialogue and see if the x95 appears in there. If it does, uninstall it and the error messages will stop. If it doesn't (not very likely), the problem is more complex and further info would be required.
Mar 20, 2014 | Xerox Office Equipment & Supplies
Cek air flow
I don't fully understand your question, however air flow issues in projectors are usually caused by clogged air intakes or filters. The remedy is usually to just remove the lamp, and blow the unit out with an air compressor. Canned air won't work, as there's not enough pressure.
Apr 29, 2013 | 3M X95 Projector
Took the tray out to empty it, put it back in but now it says tray empty and won't work
Check the two contacts at the back of the tray. Be sure they are cleans as well as the plastic space between them. Then using compressed air clean where the contacts enter the machine in the rear. Usually there is moisture back there and the machine assumes the tray is full of water.
Jul 26, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
The intake light comes on and the machine will not go thru cycle, it just hums.Water does not drain.
its obvious the drain pumps blocked, rempty machine, remove drain plug, wire mesh scoop water in middle, then take off the plastic cover with a steel like wire on it, clear out the **** blocking the pump, assemble then should be ok.
Jun 14, 2011 | Miele 23 in. Novotronic G841 Built-In...
Jura impressa f7 decalcifying pressed rinse but does not show empty button as the manual says
First you have to turn the machine off and then press and hold rinse buttom until you read empty tray and then follow the rest of the instructions. Good luck
Dec 31, 2010 | Jura Capresso Impressa F7 Espresso Machine
Reads "empty tray". Tray is empty, clean, and dry. We have tried unplugging machine and resetting, The machine has not worked in 3 days.
The tray may have some redidual soiling around the electrical contacts at the back.
Try cleaning the contacts and see what happens.
Oct 01, 2010 | Jura Capresso Impressa S9 Coffee...
I was going through the decalcifying process and the message "empty tray" displayed (Jura Compresso Impressa S8). I removed the tray, cleaned it, replaced it, but the message remains as "empty tray" and I...
Aug 15, 2010 | Jura Capresso Impressa S8 Coffee Maker,...
DVD tray will not go in
To verify there is nothing stuck in your drive, turn off your computer and try manually pushing the tray in GENTLY and feel if there is something blocking the tray moving. If there is nothing preventing the tray from moving manually push the tray in - start your computer and try it again. Use the eject function in windows explorer and try the retract button again. If teh button will not work try pushing the tray in manually again. Once the tray starts moving in it should automatically retract the rest of the way. If the unit will not retract on it's own by either method then the drive should be replaced.
Jul 29, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
Jura Capresso Impressa X90 Espresso Machine Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
