Question about HP Pavilion F1523 15" LCD Monitor
Need replacement of internal parts
The IC (i think) in my monitor got fused a couple of months back due to unsteady power supply (i guess). I live in India and am unable to locate any HP shops where I can find a replacement for the chip. It would be highly appreciated if anybody could suggest a place where it would probably be available
    Genius:
  • 2,985 Answers
My guess is no parts are available - Boards of this nature are not repairable.
Posted on May 22, 2007
  • john ash
    john ash May 22, 2007
    a further though as I am not familiar with the particular monitor.
    All these devices work on low voltage[12] so the question is--- Does this particular monitor get its low volts from a separate power supply or is it integrated with main power going straight in?
    Any fault due to erratic current will be here- so an external power pack is easily changed for a standard universal type set to the same voltage as
    the existing[now dead] one. If it is an integrated power supply then a local TV repair shop might be able to have a go with standard parts.
SOURCE:
Tv will not turn on , there is power to the tv
Hi tacgma,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the entire power supply board for your convenient, it will not require any soldering.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Please let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Jul 27, 2011 | Televison & Video
Tv no power
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Hope I helped you.
Have a nice day!
May 11, 2011 | Televison & Video
No power
Hi alscyber1,
Hope I helped you.
Have a nice day!
Apr 28, 2011 | Televison & Video
No start ,dead
Hi alonzot,
Hope I helped you.
Have a nice day!
Apr 25, 2011 | Soyo DYLM1798 Monitor
Switched tv off wont swictch back on and no stand by light
Hi eddtheduc716,
I'm assuming that your outlet is live.
Hope I helped you.
Have a nice day!
Mar 11, 2011 | LG Televison & Video
Monitor will not power on
Hi ,
Here are steps that may help you fixing the problem. You should prepare tools and multimeter.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is technical and complicated.
Hope it may help you.
Feb 11, 2011 | Sceptre x22wg Gamer Monitor
The monitor turn on and inmediately turn off
This would be due to a bad power supply board inside, replacing this will put you back into biz again around $50 for the part @ samsung.
Thanks
Your samsung expert!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Samsung SyncMaster 173V 17" Flat Panel LCD...
Chi Mei corporation 221D monitor problem no power
well i want to tell u that is a very common scenario u just replace the fuse and sometimes due to power low and high the fuse gets blown and u might also wanna check ur power chord.
Oct 24, 2008 | Chi Mei Corporation 221A Monitor
SDM-HS73P Screen Flashes
This is a problem I have seen with a few LG monitors.
Your Inverter circuit is fine (that powers the lights to your screen so you can see the image on the LCD panel) but the monitor does not like having a video signal attached to it.
  1. Bad capacitors on the power board can upset the current going to the controller board. This board included the video input circuit and the power supply needs to be stable for this to operate.
  2. The controller IC that translates the video signal into what the LCD panel controller can understand is failing. Normally this fault occurs in the horizontal and vertical input of the IC. The fact you can see the other message on screen is due to it going through it's own internal and seperate section of the IC. In this case the only repair option is to replace the internal video board. Sony will not supply the parts directly to the public, but if you are really nice, they "may" tell you where to get one externally to Sony.
Hope that helps =)
Apr 16, 2008 | Sony SDM-HS73P 17" LCD Monitor
Internal power supply
it may not be as complicated as you may think. use a hair dryer on the top right of the back of the tv.
Jan 13, 2008 | Akira EPM-420A 42 in. Plasma Television
HP Pavilion F1523 15" LCD Monitor Logo
73 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
