Question about Dell E173FP 17" LCD Monitor
My Dell E173fp monitor display doesn't work with my macbook
The monitor worked just fine with an HP laptop. After purchasing a VGA converter that matched my minidisplay port on the mac, I connected everything, turned on the monitor, and then turned on the mac. According to EVERY website I've found, the display should work automatically. The mac recognizes that the Dell monitor is there: it shows up in System Prefs/Display and shows up as an icon on the top bar, but there is NO signal going to the monitor. The monitor is functionally asleep. No amount of turning on/off has helped. What can I do to make my macbook work with my Dell monitor?
    New Friend:
  • 20 Answers
The fine print says it should work. Real life might be different. Do you have a genius bar, found at Apple stores, anywhere close? If so, make an appointment and let them make the connection for you. The genius bar is a free service and I've never found anything that they haven't been able to fix...and fix it quickly...if it's fixable.
Posted on Apr 17, 2017
SOURCE: Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Posted on Nov 21, 2007
  • 238 Answers
SOURCE: Dell E173FP 17" LCD Monitor
hi, check out the micro switches on the monitor.. let me know..
Posted on Dec 15, 2007
  • 149 Answers
SOURCE: My dell e173fp monitor has quit working. The
Is the power blinking amber? This is a DPMS power-save mode. With the computer disconnected and the monitor on, do you see the colored self-test block floating around? With the monitor on, computer connected, and you still have no image displayed, take a bright flashlight and examine the screen closely. If you can see a very dim display in the screen, the fluorescent tubes which light up the *background* and provide the vivid picture(sort of like a how an x-ray picture viewer works) are defective. The power light blinking may be the power supply sensing the non-functioning tubes or it could just be bad. If your display is under warranty, replace it. If not, trying to have the monitor repaired for this type of problem is almost as costly as a new one--and there won't be an active warranty on anything else that might fail. Hope I helped you.---Rick
Posted on Sep 10, 2009
  • 23 Answers
SOURCE: Dell 2405FPW turns out but doesn't display
Your display is fried.
Posted on Nov 12, 2009
  • 2992 Answers
SOURCE: LCD Monitor doesn't display
This is usually caused by capacitors in the monitor power supply that go bad. This site shows the procedure to open the monitor and get to the parts that are the most common failure. (They want you to pay to join to see the full-size pictures in all the steps, but there's enough detail so you can work with the small ones.) When you see the guilty parts they usually have tops that are bulging (should be flat) or even split.
It's not difficult to remove and replace the capacitors, but it does require some experience with soldering on electronic circuit boards. It's possible to do more damage if the removal isn't done correctly.
When you purchase replacement capacitors, use parts with the same value (in microfarads, abbreviated ufd or mf on the part) but the next higher standard voltage. The original parts are 25-volt rated, and you can use 50-volt parts which are only a little larger. The low voltage rating is usually why these go bad in the first place. (The manufacturers save a little by using the lower rated part.)
Good luck with the repair!
Posted on Apr 09, 2010
Monitor displays no green
I would have said bad VGA cable, but since you said you already tried a new one, have you tried replacing the VGA adapter?
Aug 29, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
My dell monitor shows no VGA cable
Check whether you have 2 display connectors on the back of your PC & you plugged into the wrong one ,Also check whether display is working while you boot
Mar 20, 2013 | Dell E173FP 17" LCD Monitor
My laptop is vga,so i have bought a vga cable,and a converter box with HDMI cable. My samsung series 5 tv will not pick up the laptop. i have tried all the options available but it just says check devices...
Wouldn't it be NICE to know what laptop you are referring to
Oh well...........maybe one day
By factory default settings the display should automatically show in the external VGA monitor. (TV. Whatever)
Your laptop has at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold the Fn key down, and at the same time tap once on the Display Toggle-Over key.
Which key is the Display Toggle-Over key?
Dunno. Laptop manufacturer and model number wasn't stated.
(One of the F keys at the top.
Acer = F5
HP = F4
Lenovo/IBM = F10
Dell = F8, unless it's Alienware - F6)
Did that? That's how it worked on your friend's TV?
Then your TV is the problem.
Settings I assume. NOT a TV tech.
Feb 07, 2013 | Computers & Internet
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
My inspiron intel laptop screen has been darkening and flickering and I tryed to do what my laptop told me but it doesn't work is there another solution?
What did your laptop tell you?
Just curious
1) "Help, I'm being held prisoner inside this laptop"
2) "I'm tired, and I'm going to bed. Lights off"
3) "Use the Brightness control, and brighten this screen up"
An LCD screen does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
An Inverter (Screen Inverter) is used to convert the power from the laptop, to the Backlight, and LCD screen.
90 PERCENT OF THE TIME the fault is the Inverter, when it's a Display Assembly issue.
The rest is a bad LCD screen.
The Inverter is a small rectangular circuit board.
It is mounted behind the Display Bezel, and at the bottom of the LCD screen.
{The Display Bezel is the thin plastic frame in front of the LCD screen. Resembles a picture frame)
Scroll the page down.
(The Inspiron 9400 and Inspiron E1705 uses the same service manual)
Suggest you connect a VGA monitor to the back of the laptop, to the blue VGA connector.
(Laptop OFF, external monitor {VGA} OFF)
You can use a VGA monitor that is a CRT. Looks like a small TV.
Or you can use a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If it is a CRT model, let it warm up.
Turn the laptop on.
The display should automatically be on the external monitor. If it isn't press, and hold down on the Fn key, then tap the F8 key once.
No? Tap the F8 key again. (Still holding down on the Fn key)
If the graphics (Display) is the same on the external VGA monitor, as they it is on the laptop's internal monitor, you have a graphics chipset problem.
Usually requires motherboard replacement, unless you know a really skilled tech.
If the graphics are fine on the external monitor, you have problems in the Display Assembly.
More than likely the screen Inverter.
Dell Inspiron E1705 Service Manual,
Pictorial guide for replacing the LCD screen, and the Inverter,
1) Use an ESD wrist strap, and connect it's alligator clip to a good ground source.
(I connect to an unpainted surface, of the metal frame of an empty desktop computer case.
You can also connect to a unpainted surface of a metal table leg )
2) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available, you can use a clean egg carton as a substitute.
Label each egg holder.
Some screws look VERY similar to other screws.
DO NOT mix them up.
For additional questions post in a Comment.
Oct 02, 2011 | Dell Inspiron E1705, Intel Core 2 Duo...
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
When I connect my unibody macbook pro to my old tv using a vga to tv converter, my computer doesn't even recognize the disyplay.
When you connect your tv to your mac, make sure the cables are plugged into the TV first, and then plug your mac into the computer.
But a vga to tv converted doesn't make much sense. Your connection should be mini-display from your mac, to an adapter to either VGA, DVI, or HDMI depending on your TV connection type.
Dec 31, 2010 | Apple Computers & Internet
I have a new macbook pro and want to use a diamond bvumd3 to have 3 independent displays. my external monitors are both Dell 2310 with 1920 x 1080 capability. I have the bvumd3 connected into my macbook...
You would have to purchase separate BVUMD3 devices in order to get multiple extended monitors. Since each BVUMD3 has one DVI port with a USB hub, the DVI port is the only port available that allows video. Using a VGA splitter will not work with our device since each DVI port is allowed to carry only one video signal through to the monitor. You could purchase separate BVU195 devices if you do not need to use the USB hub on the BVUMD3.
Dec 27, 2010 | Diamond Multimedia Diamond BVUMD3 USB...
I have a 24" aoc 2436Vh display and a new 15"
I purchased the AOC 2436Vh display yesterday. To get my MacBook Pro to work with it I purchased Apple's Mini DisplayPort to VGA Adapter. Since the monitor comes with the VGA cable, all you need is the adapter to plug it into your MacBook Pro. It works beautifully and set up is easy if you know your way around the Mac. Although the HDMI works perfectly with my PS3, I strongly recommend the Apple Mini DisplayPort to VGA adapter. I hope this helps.
Nov 11, 2010 | Computers & Internet
Dell E173FP 17" LCD Monitor Logo
Alun Cox
