Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
Rusted drawers Please advise where we can get replacement drawers as the bottom tray where plates are stacked has rusted with the plastic coating peeling off.
    Genius:
  • 2,920 Answers
Go to any used appliance shop and see if they have any for sale or if they can order one for you
Posted on Jan 05, 2009
How do I fix extensive rusting under my 2003 nissan pathfinder, I am really worried, please what do I do?
There is a paint on rust converter . You paint it on the rust and it turns it back into metal . After that i would spray the rubberized under coating to protect it.
Nov 19, 2014 | 2003 Nissan Pathfinder
My outdoor Built in BBQ has a lot of rust, but NOT rusted through. I want to get rid of the rust and then treat it and paint it to prevent further rust
If the rust is on the exterior of the grill, remove the rust using a steel bristle brush and then smooth it down with sand paper.Spray a light coating of High Temperature Grill Paint (you can find it at most hardware stores and home centers) This first light coat, will act as the primer coat. After it thoroughly dries, apply 2 more light finish coats allowing each coat to dry, before applying the next coat.
Based on the air temperature and the humidity level in your area, wait at least 3 days before using the grill.
If the rust is on the inside of the grill, just removing the rust will generally take care of it As most grill tubs are made of cast aluminum and don't require painting. What may appear to be rust is flaked on food and grease. In which case, a plastic putty knife and a roll of paper towel will take care of it.
And finally, investing in a grill head cover (made for built-in grills), will really help in not allowing the grill to rust again.
Hope this helped you and Happy Grilling!!
Jul 14, 2011 | Grilling
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Top drawer dead bottom drawer funtions fine
1-Pull out the drawer.
2-At the bottom either side has a plastice pin , use a long nose ply to pull them off.
3-The front pannel can be seperated from the tube by put both hands on the side of the front pannel with a pulling out force
Jul 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Spacesaver Microwave (manufactured 1988) that still seems to work ok, but I noticed on teh back wall under the glass tray the coating has rusted away. Should I continue to use this microwave?
As long as the oven's metal bottom is sound underneath the rust, there isn't a problem. The cooking chamber walls are so thick and highly conducting that they reflect the microwaves extremely well even when they have a little rust on them. However, if the metal is so rusted that it loses most of its conductivity in the rust sites, you'll get local heating across the rusty patches and eventually leakage of microwaves. If you're really concerned that there may be trouble, run the microwave oven empty for about 20 seconds and then (carefully!) touch the rusty spots. If they aren't hot, then the metal underneath is doing its job just fine.
Thanks.
Jun 17, 2009 | Microwave Ovens
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Apr 18, 2009 | Viking 24 in. Professional Series VUD141...
Bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Rust inside the microwave.
The areas can be sanded and painted, but first make sure there are no holes rusted through. If it's all surface rust, then sand and clean as best as you can. If you have any areas rusted through - get rid of the microwave.
Use the paint sparingly - don't try to cover in one or two coats. Best results are obtained with very, very light coats drying 10 minutes or so (depending on the humidity) in between. 10- 15 coats usually works well.
It's best to do this outside, as you'll have lots of overspray.
As far as the paint - the best I've used for the last 20 years or so comes from A.M.I. Parts. You can find them @ www.amiparts.com or toll free 1-800-522-1264.
Jul 04, 2008 | Magic Chef CMV1000B Microwave Oven
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
111 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
