I can change for digital tv hd not suported
For 24 oct 2012 ireland change analog tv with digital tv my tv stop working
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Google the model number of the set for specs---that will tell you if the set has the needed digital tuner built into it or not---if not you will need to get a box to keep pace with the change that happened.
Posted on Nov 07, 2012
  • 520 Answers
SOURCE: Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Posted on Nov 05, 2008
doctox
  • 51 Answers
SOURCE: Satellite feed is analog instead of digital
change your connector
Posted on Jan 16, 2008
bestdarngood
  • 3037 Answers
SOURCE: colour problems
Sounds like either you have a loose connection on the board or the board is going bad. Did you happen to get an extended warranty on this tv? If not, then start by opening and looking for loose or broken connections on the board. Don't touch the silver cylinders as they are capacitors. Vizio has had other problems with this happening and usually I have seen the board get replaced but perhaps you will get lucky and find a loose connection. Try shaking the tv a little to see if the picture fixes itself at all, if it flashes back to normal, then a loose connection is probably your problem and needs to get soldered back together. Let me know how this goes and whether you have any further questions or concerns with this and I would be glad to help.
Posted on May 27, 2008
  • 718 Answers
SOURCE: my philips lcd digital tv says I am recieveing
First verify that the direct TV satellite box is set to receive and display digital stations. If you old set on the sat was analog, the box may not have been reset. You may have to contact you satellite provider. Next you will have to go to the TV menu and auto program/scan in the stations. This should pick up all the stations.
Posted on Mar 16, 2009
  • 51 Answers
SOURCE: Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Posted on Aug 22, 2009
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
How do I change my service from analog to H D?
Most LCD tv's built in the last 4 years are HD compatible. Most cheaper brands tv's are 720 HD and some are full HD 1080 a little more money. Since their is no more analog broadcast as June 2009 all tv's manufactured around 2006 started incorperating the digital tuner (DTV) along with the analog so that the tv would still receive analog broadcast while the digital transistion was ongoing. All tv's with a Cathode Ray Tube (glass picture tube) are not HD compatible. First you will have 1 or 2 ports on the tv ethier on the side panel or rear panel of the set. They a marked HDMI 1 HDMI 2 or HDMI A HDMI B. If you have these ports your set is Hd Compatible. You may also need to upgrade your cable or satelllite equipment and subscribe to a HD package to be able to get HD service. You will need a HDMI cable to connect your cable or satellite receiver to the HDMI port on you tv. Call your local cable or satellite provider for options to upgrade to HD. Most over the air broadcast stations depending on your area transmit some stations in HD free of charge. A good quality outdoor antenna works best to give you stable signal. You may need to change the settings of the tv as some sets default to the 480i this is the standard digital signal.
Sep 10, 2014 | Televison & Video
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
GE TV 25GT 240, manufactured Oct 2001. Does it
This does not have a digtal tuner so you ether need a cable box or a cable provider that still sends RF analog signal over a digtal system meaning a remote converter. Some carriers do provide the cable signal still to the analog tv subscribers but you can get a digital tuner for this for under $30 bucks and participate in the coupon by the goverment. But you answer is it depends on your cable provider.
thanks and I do hope this is Very Helpful information for you when you do leave your feedback and ratings.
Dec 12, 2009 | GE 25GT240 25" TV
LCD TV
HD ready does not mean it has a digital tuner.
don't know what TV model you have but any TV with a coaxial connector will receive the analog broadcast. However; if your TV is not equipted with a digital tuner, you will need a set top box when analog broadcasts stop transmitting in Feb.
Aug 21, 2008 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
