Question about Nokia 603 black
And my phone doesn't want to connect to wifi - Nokia 603 black
  • 10 Answers
Try hard reset:
Hard Reset Nokia 603
The hard reset restores the original operating system from the ROM (memory). To hard reset your Nokia 603, you can follow below instructions:
  • Turn the device off.
  • Press and hold Answer + Reject + Camera keys.
  • Turn on the device by pressing the ON button.
  • Wait until the Nokia logo appear.
Posted on Nov 08, 2012
Doesn't connect to WiFi
Had same problem, if this is a problem at you're house, reset your router, if not restart you're phone or forget the network you are trying to connect to.
May 21, 2013 | Apple iPhone 5
I can't use my wifi on samsung jet s8003, when i open my wifi it appears 'Registration failed'?
*2767*3855#
just type this number on ur keypad
Reset it.
hope your wifi will work. All the data to your phone will be deleted
Jan 19, 2013 | Samsung Jet S8000 Cell Phone
How do you fix an android when the internet keeps shuting off
1. Try restarting the phone.
2. If you have 3G connection, see if it's turned on. If it still doesn't connect, call your carrier.
3. If you're using WiFi, check if the router is turned on and your wifi connection on the phone is configured properly.
Apr 07, 2012 | Computers & Internet
Does a sony ericsson J108a connect to wifi
your phone model doesn't have wifi modem that's why it could be connected with wifi.
best of luck!
Mar 05, 2012 | Cell Phones
I have a n5030 dell inspiron and i use to connect using wifi. The last time that i did use my laptop the wifi device is not working (the system says that there is no wifi & bluetooth devices). I use...
Make sure your wifi switch is turned on. If that doesn't work, try taking out the battery of your laptop, waiting at least 10 seconds, and then rebooting. If THAT doesn't work, try system restore and take it back until before your wifi quit working.
Aug 22, 2011 | Computers & Internet
How to get opera mini settings of my nokia 6030 and get a free internet
That phones data is GPRS only. It doesn't even have wifi.
There's also no way to ever get free internet through a phone, unless the phone has wifi and your able to connect to the wifi network, and that phone is not capable of doing so.
I'm sorry.
Aug 22, 2011 | Nokia 6030 Cellular Phone
Phone turns off all the time and gets hot did a reboot but did nothing
Does this phone have a WIFI connection? If it does, check to be sure that it's not constantly on.
In fact, turn off your bluetooth, WIFI, GPS, and any other unecessary items.
This will save your battery and prevent drain.
If that doesn't work, You may need to get a replacement phone through your carrier's warranty program.
May 09, 2011 | HTC Desire Cell Phone
How to remove the Harmonic Balancer on a 1995 Toyota Camry sedan?
4. REMOVE ENGINE BALANCER
(a) Uniformly loosen and remove the 6 bolts in several
passes, in the sequence shown.
(b) Remove the engine balancer and spacers
5. CHECK CONNECTING ROD THRUST CLEARANCE
Using a dial indicator, measure the thrust clearance
while moving the connecting rod back and forth.
Standard thrust clearance:
0.160 − 0.312 mm (0.0063 − 0.0123 in.)
Maximum thrust clearance:
0.35 mm (0.0138 in.)
If the thrust clearance is greater than maximum, re−
place the connecting rod assembly. If necessary, re−
place the crankshaft.
6. REMOVE CONNECTING ROD CAPS AND CHECK
OIL CLEARANCE
(a) Check the matchmarks on the connecting rod and cap
to ensure correct reassembly.
(b) Remove the 2 connecting rod cap nuts.
(c) Using a plastic−faced hammer, lightly tap the con
necting rod bolts and lift off the connecting rod cap.
HINT: Keep the lower bearing inserted with the con
necting rod cap.
Mar 07, 2009 | 1995 Toyota Camry
Nokia 603 black Logo
62 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
