Question about Car Audio & Video
Wiring diagram for alba ics 162 - Car Audio & Video
LG FA 162 doesnt power on.
Dry electrolitic condensator on main power unit or short circuit on speaker cables
Nov 27, 2013 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Sc403.i replace ic sla6024 on motor but?
Look at your blown fuse FU5
• Main motor/drive malfunction
• Transfer belt contact clutch defective
• Transfer belt position sensor
defective
• Harness disconnected
Jun 30, 2011 | Ricoh Aficio 1035 Copier
It keeps turning off eventhough the back switch is turned on
You need to determine if its a malfunction of the sub or just due to a loss of input. And is it always in response to, say, over-enthusiastic use?
From the manual...
TROUBLESHOOTING
If you used the high-level (speaker) inputs and there is no sound from any of the
speakers:
• Check that receiver/amplifier is on and a source is playing.
• Check that powered subwoofer is plugged into an active electrical outlet and is switched on.
• Check all wires and connections between receiver/amplifier and speakers. Make sure all wires
are connected. Make sure none of the speaker wires are frayed, cut or punctured.
• Review proper operation of your receiver/amplifier.
If there is low (or no) bass output:
• Make sure the connections to the left and right "Speaker Inputs" have the correct polarity (+ and -).
• Make sure that the subwoofer is plugged into an active electrical outlet and switched on.
• Adjust the crossover point.
• Flip the Phase Control switch to the opposite position.
• If you are using a Dolby Digital/DTS receiver or processor, make sure that the
subwoofer adjustments on the receiver/processor are set up correctly.
• Slowly turn the Level Control clockwise until you begin to hear the desired amount of bass.
If you used the line-level inputs and there is no sound from the subwoofer:
• Check all wires and connections between receiver/amplifier and subwoofer.
Make sure all wires are connected. Make sure none of the wires are frayed, cut or punctured.
• Make sure that you have configured your receiver/processor so that the subwoofer/LFE output is on.
Mar 06, 2011 | JBL PB12 Subwoofer
Calculator will not turn on. How do you replace the battery? it is a TI30xa
The TI-30Xa uses two A-76 lithium batteries. Comparable battery model numbers include:
Duracell® D357
Eveready® 357
Maxell® LR44
Varta® V13GA
To replace the batteries:
• Remove slide cover. Place calculator face down.
• Using a small Phillips screwdriver, remove screws from back case.
• Remove back case.
• Remove discharged batteries.
• Install new batteries positive side up, as shown on diagram inside case.
• Run a coin across the reset pad on the upper right hand corner of the printed circuit board.
• Replace back case, and then replace screws.
• Press [OFF], [ON/C], [ON/C].
Note: The calculator cannot hold data in memory when batteries are removed or become discharged.
Feb 16, 2011 | Texas Instruments TI-30XA Calculator
I keep getting error 2 on my car stereo it is a alba ics 101
I have an ALBA ICS101 in car CD Player/Radio. It has error 2 on the screen when I try to play a CD and it has swollowed the CD I was trying to play. How can I resolve the error and get the CD out?
Aug 15, 2010 | Car Audio & Video
Dl code
FdL is a door lock error
Possible Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Jul 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need a midi moto manual, need a wiring diagram every wire has been cut and there not color coded help!
The service manual has a wiring diagram, but you need to zoom in to read the colors.
You can download a free one at
http://www.yamaha-motor-europe.com/community/service/manuals.jsp
Nov 01, 2009 | 2008 Yamaha Alba
Universal remote code????
Hey...here's a bunch of codes that i found for alba tv's:
ALBA 003 009 011 027 028 053 062 068 083 162 169 171
Try em out, good luck!
Feb 29, 2008 | Directed 434MHZ Remote Control
Undo restriction code
i'm looking for a restriction code for my nokia6500s-1 slide IMEI No is-352027023998096 thanks barintodcyprus@yahoo.com
Feb 26, 2008 | Cell Phones
Car Audio & Video Logo
104 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
