Question about Tomtom Go Plus GPS Receiver
Tomtom 510 will not switch on.
My TomTom Go 510 will not switch on. The green light comes on when you press the start button, but then nothing happens. I've tried pressing the, well hidden reset button. I believe this is a common problem, but no one appears to have a solution.
  • sociol23 Jan 05, 2009
    It appears that the best solution is to buy a replacement Sat Nav. I've looked at several sites that will repair the 510, but as the cost is likely to be upwards of £70, it's better to buy a mew model.
  • 404 Answers
Hi!
I have in my possesion 2 Tom Tom 510s both with exactly the same problem, one was used with the incorrect (Nokia) cigar lighter charger the other suffered a Voltage spike from the vehicle it was used.
Both the input transitors have blown and as they are so small they are virtually impossible to re solder. However there is a Guy on eBay who for £80 will repair it.
I bought a different system, £70 and although basic does what it says on the tin.
Sorry to bring bad tidings,
Paul 'W'
Posted on Jan 05, 2009
My tomtom charges the green light comes on I press the on button but nothing happens
I have managed to fix my TomTom one.
The problem was two fold. First the diode D8 was blown and also the power supply chip was blown.
It is a tricky job, using surface mounted components so should not be attempted by a novice but I managed it.
I have a full set of photos etc if anyone cares to try it. I figured - NOTHING to loose!! so what the heck and just went for it. Taking it apart was fun! The surface mounted IC was easy to obtain and the total cost was about £10 plus 4 hours panic labour. If anyone wants the info just let me know and I will send the photos - but no promises - it worked for me.
I figured out this ongoing problem. I purchased my TomTom One second edition 1/20/07 for $395. I was 30 days past my warranty and had the problem of unit not turning on. Green light came on when charged.
I opened my unit up and found the sw2 micro switch broken. If you press too hard on the on/off button, this will eventually happen.
I couldn't find a replacement switch so I wired my own switch and it works now.
Oct 26, 2010 | Tomtom ONE XL GPS
Tomtom 510 - packed up
try re setting the TomTom, reset button is founded on the bottom underneath where the docking mount connect, hold down for 15 seconds, then press the little button on the top on the right side while turning on. worked for me
Jun 06, 2010 | Tomtom GO 510 GPS Receiver
Tomtom 510 will not activate. tried it with connection to electrical outlet and without being plugged into the outlet. It quit working after it was plugged into an automobile cigarette lighter plug, then...
After posting my problem, I did some more browsing and came across this on the amazon webiste:
31 of 32 people found the following review helpful: stars-4-0._v45457020_.gif Cure for not able turn on the Go 510, 16 Jun 2007 By Sirius (Essex) - See all my reviewsI like the tomtom so far the only niggle was it would not turn on once.
No troubleshooting on instructions, found cure on internet,reset button
underside. With the tomtom turned over and the card slot on top right hand
side there is a small rubber foot at the half moon shaped enterance, up at about the 10 o'clock position from the foot,but before the green circuit
board there is a small half round cut out with a hole under you need to press in this hole for a few seconds with a paper clip to reset. I wonder how many people have sent their tomtoms back that would not turn on.
Tried it & worked a treat!!! Newcastle here we come again ...
Apr 07, 2009 | Tomtom GO 510 GPS Receiver
Tomtom 510 doesn't reset
Before you keep resetting your tomtom I would intall a new battery. Call your closest "batteries plus store" or "radioshack store" and then try to reset it, it might be only the battery and nothing to do with the reseting.....
Mar 24, 2009 | Tomtom GO 510 GPS Receiver
Tomtom will not start
I had a similar problem, ther is a minute reset button where the connector is under the unit, it requires a pin to press it!
Mar 22, 2009 | Tomtom GO 510 GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
Tomtom not switching on
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
Apr 02, 2008 | Tomtom GO 700 GPS Receiver
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
Sat nav
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Jan 12, 2008 | Tomtom GO 700 GPS Receiver
Tomtom Go Plus GPS Receiver Logo
158 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
